Apple iPad (16 GB) WiFi Tablet PC Logo
Fausto Perez Posted on Jul 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reseting my IPAD
My IPAD will not restore and remains in constant restore mode.
Anonymous
Level 2:
  • Expert 233 Answers
  • Posted on Jul 25, 2012
Anonymous
Expert
Level 2:
Answers
233
Questions
0
Helped
72287
Points
588
Hi There,
You have to enter DFU Mode (iPad LCD will be black) before restore, and
please follow this step by step to enter DFU Mode:
  • Attach the phone to the pc
  • Turn the iPad off
  • Hold power and home together for *exactly* 10 seconds
  • Release power but keep holding home until the pc beeps as a USB device is recognized.
  • At no point will the display come on. Now your restore should work.
regards,
dm
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
How can i get passcode
Hi Donald. Do you forget the passcode?
If you have synced your iPad with iTunes before you forget your iPad password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked iPad while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below. The following steps will show you how to reset iPad password with iTunes.
  1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
  2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
  3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
  4. In the Summary window, you can see the option "Restore iPad". Click it and follow prompts to choose the latest iTunes backup to restore your iPad.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPad without any passcode. And you can set your new password on iPad.
How to Reset Password on iPhone
2answers
Why is my iPad showing the plug with an arrow pointing to the iTunes emblem
Your iPad is in restore mode. If you boot the device while holding the home button, it will boot into restore mode for a clean firmware install or a restore from backup.
you can either hard reset the device by holding the sleep/wake and home buttons down simultaneously for 8 seconds, tether it to a computer and complete the restore, or just leave it alone for about 20 minutes and the restore timeout wll kick it back into normal operation as long as there is a good firmware install present
3answers
How do I can reset my IPad?
Try putting your iPad into DFU mode, and then restore it with a computer with iTunes installed.
Please note: this will erase and delete everything on the iPad.
The article can be found here, on Apple's website:
http://support.apple.com/kb/HT1808
Hope this helps!
2helpful
4answers
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
2answers
Reset ipad 1
Unfortunately I'm afraid your iPad is stuck. To fix this problem, you may in need of a iPad restore software to reset your iPad. I hope this guide may help you: iPad Stuck in Recovery Mode at Apple Logo
1helpful
2answers
Forgot reset password
you can reset your iTunes password from the iTunes web site, and the associated em address. and restore the iOS device on your computer with the iTunes app
Ipad password reset
In fact, there are different ways to reset iPad password. You can follow below method to have a try.
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
For more methods, check: How to Unlock iPad?
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
