I assume you are using XP. Try these steps.
1. Open 'Sound and Audio devices' in Control Panel.
2. Select 'Advanced...' button near bottom.
3. Select 5.1 system
4. Start playing a sound.
5. Set the volume control of the subwoofer to the middle position.
6. Open volume control and adjust Master volume to a comfortable level (i.e. until there is no hum).
Also make sure you haven't muted any sound device except microphone. I think your problem is you have set it to the maximum level. So decrease it.
7. Mute the sound and check.
Good luck! Let us know the result.
the circuit board inside the amp is fried how do i get another board?
Fried is not good - I can't say for sure with your particular unit but there is usually just one main board and "fried" means possible burned parts and/or the board itself. That could be the result of a problem in the power supply or on the flip side my have damaged the power supply. You're likely going to need a new amp. What's the model of the amp?
