Question about Pride Celebrity X 3-Wheel Electric Scooter
What makes the speed pot go bad on a 3 wheel celebrity x scooter
When key is turned on code light flashes 7 times
    Novelist:
  • 60 Answers
Yup you gt a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pt is aa variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this
You may also need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should movee gracefully up to 30k down to zero as the pot dial scooter speed increases. Faaailure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Posted on Jul 23, 2012
  • miguel villanueva Jul 23, 2012
    thanks alot for that update im a above the knee amputee that cant afford to send to an authorized dealer for repair i just do the best i can with what i got thank s again george!!!!!
SOURCE:
  • 29 Answers
SOURCE: Celebrity Pride SC440 scooter makes continuous clicking sound
the motor break assembly is going bad, if not replaced soon it will quickly draw down your batteries. smithrm70@hotmail.com
Posted on Sep 19, 2009
gewiz
  • 1367 Answers
SOURCE: The lights indicate there is
Hi can you tell me the flash code ? how many imes it flashes before there is a pause etc.
to help you with this check the manual
http://www.pridemobility.co.uk/docs/UK_Celebrity_X_om.pdf
goto page 35.
Regads
Gewiz.
Posted on Jan 02, 2010
  • 16 Answers
SOURCE: Pride celebrity x 3-Wheel scooter My scooter is
Hi
Trade it in for an 8kph Speed, as i am assuming that yours is only a 4 kph Speed,
Gerry.
Posted on Aug 01, 2010
  • 16 Answers
SOURCE: pride celebrity 4 wheel wont turn on
Hi
Please Check that your Freewheel Lever is Fully in Position as if is Slightly out of Position it will Not Work,
Gerry.
SOURCE: instruction manual for pride mobility sonic & celebraity scooter
Here is the link to all pride manuals for power mobility.All files are .pdf and searchable.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
Posted on Jan 04, 2012
On a celebrity x i turn key on led lights but as soon as you touch throttle it flash code 7 and does not move
Hi code 7 is a speed pot error CONTACT A PRIDE DEALER. www.pridemobility.com. or call (877)706-2032 cheers
Mar 20, 2016 | Pride Celebrity X 4-Wheel Electric Scooter...
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
May 24, 2014 | Pride Mobility Products Pride Celebrity XL...
Flashing code 1, 3 speed pot fault
Usually turning the key off and removing it then re inserting the key and turning it back on without touching the paddle levers. If that doesn't fix it then the speed pot will need to be replaced.
Mar 16, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Pride mobility scooter celebrity x flashing 5 times not working
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
Nov 04, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
What makes a speed pot go bad on a celebrity x 3 wheel scooter?
Yup you got a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pot is a variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this
Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should move gracefully up to 30k down to zero as the pot dial scooter speed increases. Failure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Jul 23, 2012 | Pride Health & Beauty
I HAVE A CELEBRITY DX SCOOTER, IT IS 4 YEARS OLD. I HAVE HAD NEW BATTERIES FITTED, BUT THIS LAST 3 MONTHS THE SCOOTER RUNS FROM NORMAL SPEED TO SLOW AND SLUGGISH THEN BACK TO NORMAL EVERY FEW MINUTES.CAN...
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
Jul 05, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Pride celebrity 4 wheel wont turn on
Hi
Gerry.
Nov 02, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Pride Celebrity X 3-Wheel Electric Scooter  Logo
306 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
