Actiontec Qwest Branded - Centurylink Pk5000z Dsl Modem Wireless Router Buy Dont Rent Logo
Posted on Jul 23, 2012
How do i conect to my wirless router setup
Need to connect the wireless router set up
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
227
Points
MAKE SURE THAT YOUR LANDLINE IS CONNECTED TO YOUR WIRELESS AND THEN FOLLOW THE INSTRUCTIONS ON THE DISC
I cannot connect to my wireless linkys router..Any hep will be appreciated
I think you should reset the router and reconfigure it manually.
Press and hold the reset button on the router for 30 seconds. Release the reset button and wait for 30 seconds.
Power cycle the router and reconfigure it manually.
See Linksys router setup manual
tip
Setting up Wireless on router and wireless security
For setting up any router you can follow the below simple steps
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.1.1 or http://192.168.0.1 and then type the username and password default usernames and passwords can be found in router manual.
  5. Once the router setup page is open you can confugure the router easily without the CD setup.
  6. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  7. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  8. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  9. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  10. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
All the best with your wireless router configuration and security setup
Regards
Vikram
on Dec 02, 2009 • Computers & Internet
Dhcp is not enabled for wirless network connection
you will need to open the setup page of the router. Do u have any computer connected to the router?
If not then do you have any computer online using the wireless connection ?
on that computer, you can open the setup page of the router.
On this page you will get all the settings of the router.
Click Here
for step by step by instructions
1helpful
Can only get a limited conection on wirless but works fine when connected with cable samsung net book
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Click Here for step by step solution
1helpful
Wirless router problam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
OR
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
How to secure my wirless connection
You could set up a mac address filter with just your routers address or you could set up a wireless key that only your computer uses. Here is a quick tutorial:
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx#3
1helpful
2answers
I WANT TO SETUP MY ROUTER TO WIRLESS
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Go to START and find RUN, then type in CMD and hit ENTER, should throw up a black box (Dos window) you will type IPCONFIG and it should give you an adapter gateway ip address like 192.168.0.1 or something like that, from there close out that box and launch internet explorer or firefox or netscape or whatever browser you use. Type in the ip address where you would normally type www.google.com. Hit ENTER, this will interface you with the router. It might be password protected. Usually the username and password are both the word admin. If not look at the bottom of router for password. Look for wireless tab once in router and select network type as wep. Look for the key that the router automatically generates. This will be your wep key. Now your wireless connection will be secure. Hope this helps...Tennis123
I had my DSL disconnected. I am using cable internet w/Comcast. I've DIR-628 connected to Mot-SB5101 Cable Modem. This setup is working fine. However I'd like to use my old DSL/Router 2wire 2701 to connect...
First you should see a wirless icon on the botom left of your screen wich is on the task bar. The say view wirless networks or what ever it would say then you should see a list of avalible networks at that time. The slect the network that you own an say conect. When conecting it way ask for a WEP password which is located on the router. I hope this will help you.
1helpful
I am trying to set up a wireless connection to our LAN at home. I need help.
Well ther should be a wirless icon on the botom right corner of your screen when trying to acess it form a notbook computer. You will need to right click on it and say view wirless networks. Then find the one that is your and try to conect if it need a WEP password it is on the bottom of router.
Top Actiontec Computers & Internet Experts
Jesse Walters
Jesse Walters
NOEL
NOEL
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
