Model 000141 Serial No. 00093664 T-Kondi 9604 Viking Range Corportion from Greenwood, MS USA Appliance Repairman replaced burned out wires that had fused together; pump burned out; he believes electrician will require wiring manual as the fuse box shows electricity is going to the dishwasher; yet, the motor is not working. Previously, dishwasher extremely HOT ON INSIDE WITH THE UNIT HEATER REMAINING ON FOR UNEXPLAINED TIME. Heater not known to be working or not at this writing. Thank You.
SOURCE: Viking Dishwasher - Model VUD 141 I need to
Hello, welcome to fixya
Here's what works for me, move the rack stops to the left if you haven't already and then the rack itself. i.e.
and
Now you'll need to remove the bumpers at the back of the rack rail...
i.e.
push down on the bumper as shown
and pull it down and out at the same time...it takes some force, you can use a small screwdriver.
Now you'll need to slide the rail all the way out as shown, but careful not to let the ball bearings fall into the sump area in the process.
I usually hold the broken piece in place while removing the rail...
...( they come in a kit at "repairclinic.com" under number 1394379 like shown here )
The trick now is to install the balls into the holders first
and the holders into the stationary part of the rail on the inside wall...
The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place...
Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of how it needs to be done. Please take a moment to rate the assistance I provided here today favorable and a brief testimony is also appreciated when providing free solutions.
Thanks for visiting "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
I should also mention you as I alluded to, be sure none of the old 8 ball bearings didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko/Viking dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Again, good luck :)
SOURCE: Need the wiring diagram for the front panel/door
This is all I could find go to this address www.specsserver.com/CACHE/FILE5412.PDF at the very end is wiring diagram but its not in detail
SOURCE: Viking Dishwasher Timer Dial not advancing
The timer has given it up. The motor has probably stopped working or the gears are jammed. You'll need to obtain and change the timer. Generally, there are face mounted screws that may or may not be behind some covers. Remove them to get to the panel that holds the timer.
