Water leaks into the refrigerator section
SOURCE: Water is leaking around the water filter area
take and shut off the water to the unit then take the filter base off so that you can see where the tubing goes into the filter. you may have to replace the tubing if it was cut during the move.
SOURCE: water leaking onto floor when defrosting automatically
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
SEA BREEZE TIP's
SOURCE: Gibson/Frigidaire GRS20ZRH - Refrigerator section
Check your fan that goes from the freezer to the refrigerator. It is probably faulty. If not then check your defrost timer.
I hope this helps
Please rate me
SOURCE: Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
SOURCE: My Frigidaire refrigerator leaks water through its
you have a bad water inlet valve. replace the water inlet valve.
Hi friend, thank you for your post!
Based off your post you are having trouble with frost on your rear wall and water dripping from the top middle section on the inside of your Frigidaire refrigerator. Sounds like you may have a possible problem with an air leak or water leak. I would suggest checking your seal to make sure there is no leak. You can do that by placing a dollar bill between the body of the freezer and door. If the bill comes out easily then the gasket may be causing frost to develop due to an air leak. I would recommend exchanging the gasket out. If the gasket is sealing properly then it could be an issue with the water line and you should perform a manual defrost that could help clear out any restrictions in your water line. To perform a manual defrost you would need to disconnect power from your refrigerator for roughly four to six hours. I hope this information is helpful. -Matt
Hey friend, thank you for the post!
From my understanding you have water leaking out of the freezer of your Frigidaire refrigerator and onto the floor. I would like to ask you a couple of additional questions. First, do you see where the water is coming from? Secondly, what is the model number of your appliance? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side it can be found on the right hand side. I look forward to hearing back from you. -Matt
