No light showing when on charger, won't turn on, won't reset or power up. just a black screen
SOURCE: my coby tablet won't open
Hi s112ronnie,
If your Coby tablet suddenly has no response or powers off, an elec-trostatic discharge may be the cause. In this circumstance, please follow these procedures for recovery:
1.Reset the player (use a paper clip to gently press the Reset button (on the bottom of the player).
2.Turn on the unit again
NOTE: Back up your data to an external source prior to performing reset.
Hope it helps.
Thank you for using FixYa.
SOURCE: My device won't turn on
Sounds like the internal battery is too weak to run the device. Let it charge for a while and see if it will turn on after say about 30 minutes.
SOURCE: my tablet froze and now
Hello!
Here you can try the following procedure to unfreeze your tablet:
First: Hard Reset
1. With the Samsung Galaxy Tab turned off, press and hold the VOLUME DOWN button, and then, briefly press the POWER button.
Second: Remove SIM card
1. Take out the SIM card and put it back in.
2. Then it will turn right on
from the beginning if you press the power button.
3. If that doesn't work,
it means it needs to charge.
Third: Resets
Try one from the procedures below
1. Hold the POWER button for 10 seconds
2. Hold the POWER and UP VOLUME for 10 seconds for recovery mode
3. Hold the POWER and DOWN VOLUME for download mode for 10 seconds
If none of them works. Remove the battery and leave it off for 10 minutes. Then, return back the battery. If problem persist in the future, I would recommend to replace the battery.
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
SOURCE: My acer charger got wet, I thought I dryed it off
You could go to the place you bought it or another tech store and see if they have another tablet like yours lying around so you could test out and see if it is just your power cord that needs to be replaced. Because most likely it's time to buy a new power cord. Hopefully you didn't fry the tablet's motherboard also that's why you should test out the power cord first.
