Zanussi ZBF660 Electric Single Oven Logo
ALEXIKAV Posted on Jul 22, 2012
HOW TO SET CLOCK ON MIELE H806 OVEN - Zanussi ZBF660 Electric Single Oven
hdwrsft
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Nov 20, 2012
hdwrsft
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
0
Helped
5699
Points
8
On the control panel: Beneath the label "Cooking Time," press the "Duration" and "End" buttons simultaneously and hold using your fingers on your left hand. An arrow will display above each button.
Using your other hand, rotate the knob to the left of the panel to adjust/set the time one direction or the other. Once set to the appropriate time HH:MM, release your fingers from the "Duration" and "End" buttons.
The time is set.
Miele imperial 90 cm oven EBJ 1852 UT removal from enclosure
The way to do this is find the Installation manual and then reverse it. Or contact Miele direct.
https://www.google.com/search?q=miele+imperial+oven+ebj+852+installation+manual
May 17, 2022 • Miele Ovens
3answers
How do I set the clock on the Miele oven?
I don't believe this model has a clock feature - just cooking timer. I checked through the operation manual and did not find any indication of a clock function. The manual is available here:
http://www.mieleusa.com/manuals_pdf/Residential/Ovens/H350-2_us.pdf
2answers
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Miele H 5240 B CS oven Purchased E & S Trading, Ashburton, 1 October, 2010 When I press the arrows and the OKin between, about 70% of the time nothing happens. Sometimes wetting my fingers seems...
Hi the is a two year g/tee on all Miele appliances. I would contact Miele and book a service call. The appliance most likely requires new clock. Modified clocks are available which allow you to change setting via control knobs rather than keypad.
2helpful
2answers
Miele steam oven keeps wanting to be descaled after descaling!
yiou have to enter in service mode. ' 1- turn oven to off position 2- open door 3- turn knob counter clock wise to defrost position 4- push 3 times tempeture button until #02 appears on screen 5- with the + button go to 67 6- close door and wait 5 minutes until it resets by itself. enjoy your oven once again.
1helpful
Need to set time on Miele Oven H398B2?
Turn the upper oven on. Hit 'MORE' once or twice until you see 'SETTINGS' touch that and navigate to 'CLOCK' Once there, you can enter the time using the keypad. Hit 'OK' to exit. You can download the manual from the Miele website or request a printed version from them.
2answers
How to set clock and timer
reset clock, set clock on the right time by clicking + & -
H348 B2
turn of at mains, wait 5 mins and turn back on then consult your handbook to set clock. i suspect you have the oven on automatic by mistake. if this don't work, you may have a problem with the clock itself. you can bypass the clock by connecting together the two contacts adjacent to the clock relay
Top Zanussi Ovens Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
