Question about Hitachi 50V500 50 in. HD-Ready LCD Television
TH ETV TURN OFF ITSELF
I HAVE A HITACHI TV 60V500A AND I HAVE A PROBLEM..AS I TURN THE TV ON THE POWER BUTTON THE LAMP AND THE TEMP BLINKS ALL AT THE SAME TIME AND A FEW SECONDS IT TURN OFF BUT ITSELF..BUT THE LAMP BUTTON IS NOW NO LONGER BLINKING BUT ON..
The cooling fan could be going out
Posted on Dec 14, 2008
    New Friend:
Hitachi tv power button keeps flashing red and green when turned on but wont work, have tried switching off at main switch for an hour but still not working??? help!! x
Posted on May 30, 2011
SOURCE:
My TV is Hitachi 60V500A rear projection TV. I replaced the bulb but still showing lamp light. What should i do?
Remove the lamp cartridge and make sure the wiring is secure, if ok then reinstall, slowly and carefully making sure the lamp is seated correctly, do all this while the tv is unplugged - of course, also make sure the all the covers on the tv are securely installed or the tv will not power up. good luck
Nov 06, 2010 | Hitachi 50VF820 Projection TV
On hitachi ultravision when you turn on the power button blinks green and lamp button blinks red. What is wrong?
When was the projection lamp last replaced in this tv?The projection lamp in the tv now is about 1 1/2 or 2 years old and the tv been on and watches like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Sep 04, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi tv LCD blinking red light tv wont' turn on. replaced lamp model 60V500A
I have hitachi lcd rear projection tv model 60v500A at first I was getting a red spot on centar of tv with in two mounths the spot got bigger. I chanched the lamp but now i don't have a picture, the red indicator on tv is now blinking.
Aug 10, 2010 | Hitachi Televison & Video
Lamp light on after i replaced the blown lamp Hitachi 60v500a
Was the tv working before you replaced the lamp? if it was then make shure you have reinstalled the new lamp and the door exactly as removed, there is a disconect switch on the door that has to close when the door is reinstalled,or sometimes the ballast may go bad at the same time.Hope tha t will help you fix it.
Mar 19, 2010 | Televison & Video
Power light is on, temp light blinks, and lamp light blinks, no picture.
Its possible that your lamp is bad, or you have not closed the lamp cover properly. If you don't close it, the sensor will tell the TV not to turn on.
Feb 04, 2010 | Hitachi 42V715 42" HDTV
My hitachi tv does not turn on the lamp and temp
Try replacing the lamp. Look in your manual to see what the lamp number is and search the net to find a replacement. lamps are not hard to replace, you can evern go to youtube.com type in how to replace a hitachi lamp and see a video. Hope this is helpful.
Oct 26, 2009 | Hitachi Televison & Video
Hitachi 60v500a projection turns itself off
i have the same problem, did you ever get an answer?
May 31, 2009 | Hitachi 60V500 60" Rear Projection...
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
762 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
