I've removed the little round door on the front lower right, found the black "winged" filter cap, unscrewed that only to be met with the white plastic that i think should have come off with the black screw cap! I've no idea how to remove that, been trying for 2 days! Even try putting black twist thing back on over and over in an attempt to bring the white unit with it but nothing! Any ideas?
SOURCE: bOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
This is a two person job. The spring part of the metal ring goes at the 6:00 position (note the groove on the metal part of the machine). Fit the ring into the gasket as much as you can on the hinge side. While one person uses pliers to stretch the spring, another person uses a flat head screwdriver to move the ring into the gasket groove. The trick is to stretch the spring as straight and close to the machine as you can or else the ring pops off and the gasket has to be reset.
