Question about HTC HD7 Cell Phone
Htc hd7 black screen
My home screen is black. the lock screen is fine, and when at the (black) home screen, the volume up and down animation are visable. along with the power off animation. Only the home screen is affected. Is it toast, or savable? I love this phone and want to save it if at all possible.
  • hayden james Jul 22, 2012
    At the lock screen, the LCD and glass screen apear to be fine.
SOURCE:
ejkudelka
  • 1188 Answers
SOURCE: I dropped my htc hd7
It sounds like both the glass, and the inner LCD has been damaged. I think the LCD needs replacing because you cannot get any picture up, but since it has turned black when you use it, it sounds like it needs replacement. I do repairs and I am in the directory, but you may prefer finding someone local who can help.
Let me know if you need further help.
Best regards,
EJ Kudelka
Posted on Dec 26, 2010
SOURCE: my htc hd7 wont send text messages and will not
My HTC hd7 won't send or receive text message
Posted on Feb 21, 2011
  • 3 Answers
SOURCE: my htc hd7 mobile phone is not letting me install
if it is locked you will not be able to install apps.search google for unlocking instructions
Posted on Mar 31, 2011
SOURCE: how do i sync my htc hd7 phone (windows mobile)
I have Outlook 2010 client on my PC. My ISP mail account is forwarded to Outlook via POP3 mail account. I also have a gmail account to which I forward all mail to from my ISP mail address. My gmail calendar is bi-directionally synchronised to my Outlook calendar using 'Google Calendar Sync' and likewise my gmail contacts are bi-directionally synchronised to my Outlook contacts using 'Go Contact Sync'. then it was a simple matter on my Windows Phone 7 to create a Google mail account to my gmail account. I can create contacts, calendar entries in either Outlook, Gmail or my phone and they are all sync'd with each other. 'Google Calendar Sync' and 'Go Contact Sync'' are free downloads.
Posted on Oct 20, 2011
ashlocked
  • 1140 Answers
SOURCE: my tmobile hd7 is stuck
It somehow need to update the phone with the same firmware,many issue regarding this problem,but give this thing a try,might be your luck day.
To start up with,
* Turn off the phone.(be sure battery is fully charge)
* simultaneously press volume up and down then press power ON.
* a message comes out,simply follow instruction,you may release the volumes now then press down volume key to proceed with the hard reset(camera button will be the enter key) .just wait the process until the phone reboot.DONE
Here's a video so you can visualize the procedure.
Posted on Aug 08, 2011
How do i fix a frozen htc hd7 t-mobile phone?
All you need do is to HARD RESET the phone.
1. Press down the volume up and down button
2. Briefly press the power button still holding down the volume button
3. release the volume button when the screen flash a reset instruction menu, then press volume down butoon to reset your device.
Apr 26, 2013 | HTC HD7 Cell Phone
Htc inspire 4g stuck on lock screen and won't unlock
Please note that all data will be deleted from the HTC Inspire 4G as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your HTC Inspire 4G is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and hold the Power button until the device turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
Aug 29, 2012 | HTC Inspire 4G Smartphone
Free unlock code for htc hd7
HTC HD7 is latest Model Phone,So free unlock code is not possible to get for the model...You need to pay for this model.Visit the site
Mobileunlocksolutions.com/htc-hd7/rs1wp9/ get the Unlock code at reasonable cost and unlock it from network lock,then use with any GSM Network sim card in the phone...........You need to specify the network it locked now,country and get the code.
Aug 17, 2012 | HTC HD7 Cell Phone
I place a four diget code on my phone and locked for the screen and forgot the code
remove and reinsert the battery, press and hold the volume down then press and hold power, you should be in hboot mode, press power once, you should see factory reset among the options down, scroll to it and press power. Note: all data will be lost.
Nov 11, 2011 | HTC HD7 Cell Phone
My HTD HD7 has suddenly decided to not respond to any touch functions whats so ever. The screen nore the three function buttons at the bottom register any touch. The remaining buttons, power, volume and...
I'm having the exact same problem.
An hour ago I was using my phone fine, and then it randomly shut off and turning it on again I have no touch function, while the volume and power are fine.
I've done everything recommended, much like you and having no luck :/
Oct 10, 2011 | HTC HD7 Cell Phone
I can't install any apps on my HTC HD7,keep getting a message not available please try later
First of create a new Live id going to www.live.com then , make sure you select the country as US and find a valid zip of one of the US states .
Now hard reset the phone and then go to market , login with the new id .
Here is how you hard reset
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
Aug 12, 2011 | HTC HD7 Cell Phone
My tmobile hd7 is stuck on the start up htc screen,how can i fix it?
To start up with,
Aug 08, 2011 | HTC HD7 Cell Phone
My htc hd7 wont let me send text messages
It may be because of network locking,Your HTC cell phone is locked to use specific networks sim card.You can unlock your HTC cell phone by Unlocking Code.
You can get unlock code at cheapest rate by HTC HD7 UNLOCK CODE provider with Instructions.
THANKS ! ! !
Apr 29, 2011 | HTC HD7 Cell Phone
I want to reset a HTC HD7 but i dont know how. can you help me?
1. From the Start screen, tap wp7arrow.png in the upper-right corner.
2. Tap Settings.
wp7settings.png3. Scroll down and select About.
wp7about.png4.Tap the Reset your phone button.
windows-phone-7-reset-button.png5. Confirm your selection by selecting Yes. Then tap Yes again.
Your HTC HD7 will then go through the process of resetting to factory default settings.
Option 2 - Resetting using the hardware buttons
You can also use the buttons to perform a hard reset. This comes in handy if the screen is frozen and you can't access the phone.
Mar 08, 2011 | HTC Cell Phones
HTC HD7 Cell Phone Logo
235 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
