In the past it indicated that the head was dirty and needed to be cleaned, which we did with a Sony cleaning tape.
SOURCE: Partial static in playback and record even after head cleaning
Replacing the cylinder with video heads part number A7048897A will cure the problem. If you need more help please advice. Arpi
SOURCE: error message 31:22 reinsert cassette tape
reel sensor is the problem of your camera it is a common problem to that model,maybe the pinch roller is loosen to the post cause of the lock of that is been broke..that roller is that one that pulling the tape...only a technician can put it back to the mechanism and replace that lock...in sony service they replace the whole assembly and cost a lots...i suggest find other service center for fixing it...hope that roller is not lost in your camera...
SOURCE: reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
SOURCE: Tape Cleaning on-screen warning
Depending on the age of the camera/cassette, it may be that the heads are not just dirty, but are actually worn down. The gray bars are the DV equivalent of snow - data has been lost or at least cannot be displayed. If cleaning doesn't solve the problem, the heads probably need replacing. Depending on the age of the camera, it may be more cost effective to upgrade to a new camera.
SOURCE: head cleaning
Error C31:42 it means FG fault during normal drum operations. Some it happen when ur head drum is Video head is dirty.Here if u try to cleaning tape it will not work. So u need to open the compartment clean manualey with the cleaning cloth which u have to buy from Sony
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
