Orion VR213 VHS VCR Logo
Posted on Dec 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Orion VCR 213 will not record with converter box
Connected Orion VCR 213 after connecting TV converter box and it will not record, I just get a blue screen and the tape runs but does not record...any suggestions? I followed the set up instructions and everything else works
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1423
Points
Tell the vcr to record the output channel of the converter box (usually 3 or 4).
Michael Borelli
Level 3:
  • Master 979 Answers
  • Posted on Dec 29, 2008
Michael Borelli
Master
Level 3:
Answers
979
Questions
Helped
328560
Points
1751
The chain of cabling that you have should go like this; First in line should be the wall supplying the cable box. Then, the cable box connects to the VCR, then the out of the VCR should go to the TV. Select whatever channel you desire, make sure that the VCR is on Channel 3 or 4, (Whichever the back of the cable box is set) then select 3,4 or line/AUX to see the results....accordianman
1helpful
Digital programing
By the look of it you would need to connect a digital set box to it to record any TV programs, seeing that most countries are switching off or have switched off analogue TV. The video would then pass any signal it had recorded via a scart lead to any TV with one of those sockets.
Im not sure how to hook the converter box up to it
For a digital to analog converter box, connect your antenna cable to the converter box. Then pick your output connection. Either set the TV to channel 3 or 4 and connect the coax out from the converter to the TV or connect the composite video (AV) to one of the A/V inputs on the TV (change the TV source to the appropriate input). The source is changed with the remote (TV/Video button).
If you have other devices like a VCR in the connection sequence, you could connect the converter box to the VCR (and record on channel 3 or 4) and then connect the VCR to the TV as above. You will be limited to recording and watching the same program unless you get another converter box or tuner.
Programming the remote will depend on the box. For other set top boxes, the connections will be very similar.
I hope this helps.
How do I tape onto a vhs from analog tv with converter box?
There are 2 options-
Option 1
Connect the coax cables in the following order.
1 From the wall to the input of the converter box.
2. From the output of the converter box to the input of the VCR.
3. From the VCR to the TV input.
Here is how you record with this option.
1. Tune the converter box to the channel you wish to record.
2. Turn the channel on the VCR to channel 3 or program the VCR to record channel 3 this will record whatever channel you have your converter box set to at the time of the recording.
Option 2- (will not work on satellite)
1. From the wall to a 2 way splitter (made for digital cable. General rule of thumb with digital cable is gold does not usually mean good.)
2. One output from the splitter to the converter box and the other to the input of the VCR.
3. Connect an Audio Video (RCA (yellow/red/white cable)) from the VCR to the TV input.
4. Select the appropriate input on the TV for the VCR.
Here is how you record with option-
Tune the VCR to the channel you wish to record and push the record button or program the timer to record the channel and time that you wish.
Note- with this option you will only be able to record channels that you would receive without the converter box. Also each time that you split the cable line you loose part of your incoming signal and depending on how you house is set up this option could affect the quality of your digital signals on the converter box.
1helpful
2answers
I have 2 DTV converter boxes - one for TV and one for VCR. The wiring is exactly as prescribed by manuals and FCC. VCR does NOT record programs from TV - altho it plays back pre-recorded tapes OK. I have...
Use only one box.
Connection should be:::Video Source(cable, antenne) connected to converter box:::::Converter box connected to VCR:::VCR connected to TV.
Try this connection and let me know how it goes.
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
2answers
Getting my VCR to record from the TV with a converter box hookup
Hook up antenna to converter box then from that out to the vcr's input (red,white, yellow connections are better than coaxial).
1helpful
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Vcr & dvd & a CONVERTER BOX
Right, you don't have to plug DVD/VCR to box, just straight to TV to operate. If you wanted to record hdtv programs from the box to the vcr or a dvd recorder then connect box to vcr/dvd recorder to TV.
2answers
How to Record TV Programs w/o Cable Box/Satellite Receiver?
if there are rca ports on the front of the vcr which are output, connect those to the tv input 3, the input to input connection is definitely not going to work...
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
