The paper feeder grabs several pieces of paper at once instead of just one. How do I fix this?
SOURCE: hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
SOURCE: not grabbing paper
Try cleaning the rollers again and fan the paper. When you clean the rollers, use alcohol and a lint free cloth. Don't put too many sheets in the feed tray.
SOURCE: My MP460 printer wont grab paper and feed through
It sounds like the pickup rollers are worn or damaged and would need to be replaced
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Leading
cause of paper jams is debris/foreign objects that accidentally fell into the
paper feed area. Please follow steps below to fix the problem:
1.
Remove the sheets of paper from the feeder.
2.
Grab a flashlight and look inside the feeder for any debris or foreign objects.
3.
If you're willing and physically able, you may also turn the printer over. Any
debris should just freely roll out from the feeder.
4.
If feeder is clear, place the printer back on the table, open the printer cover
and remove the cartridges.
5.
Check the cartridge area for any obstructions/debris in the cartridge carrier's
path or the paper path.
6.
If cartridge area is clear, close the cover.
7.
Re-brick your printer. Pull out the power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Leading
1. Remove
2. Grab a
3. If
4. If
5. Check
the cartridge area for any obstructions/debris in the cartridge carrier's path
or the paper path.
6. If
7. Re-brick
your printer. Pull out the power supply, black box where the power cord is
plugged in at the back of the printer, and put it back after 30 seconds.
8. When
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
