Canon PowerShot S500 IXUS 500 Digital Camera Logo
Dara Chan Posted on Mar 09, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Show the Date stamp on the picture
I want to have the date stamp on my photograph that I have taken. I tried to go the setup menu and look for the date stamp option. However, this option is in gray color and I can't do anything with it. Thank you.
Anonymous
Level 2:
Scholar:
  • Expert 113 Answers
  • Posted on Mar 09, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
113
Questions
0
Helped
173392
Points
281
One reason why the date stamp is not showing would be that you have not set the system date/time. The date/time resets everytime you take out the battery. Please go to this link and download the userguide... http://alpha02u.c-wss.com/inc/ApplServlet?SV=WWUCA900 file name : PSS500IXUS500CUG-EN.pdf ...Go to page 26 which will tell you how to set the date/time and then go to page 109,113 for the date/time to be displayed on the photographs. Please tell me if this helps
Can I turn the date stamp on for a nikon coolpix 2000 camera. It tells me I have an internal date but the date is not showing up on my pictures.
Firts set the time and date
Go to "Setup" menu
Highlight "Date"
Display DATE menu
change yera. miont, day , hour
left menu
Time and date of recording is included with all pictures
taken with your Nikon digital camera.
try again , take a picture and look if show date time
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
How do you stamp date photos on the M580 easyshare camera
1. Press the Menu button.
2. If your camera displays a menu with tabs at the top:
a) Press the Right/Left buttons to highlight the Setup tab.
b) Press the Down button to highlight Date Stamp.
c) Press the OK button to add the date stamp to new pictures.
3. If your camera does not display a tabbed menu:
a) Press the Down button to highlight Date Stamp. NOTE: Depending on your model, Date Stamp might be within the Setup choice.
b) Press the OK button to add the Date Stamp to new pictures.
3helpful
How do you date stamp pictures
2helpful
I want to switch off the date stamp in my pictures taken with A480, please.
Press Menu, scroll down to "Date stamp" and across to select off, date or date and time, then press menu again. The date stamp only works in Postcard mode, so if you set a different picture resolution, that will also stop the pictures being date stamped.
I have a kodak EasyShare C315. I need the date stamp but can't seem to make it work on pictures. I have set and reset it. How do I make it show of pictures?
In any mode, press the MENU button. Use up/down to highlight Setup (three horizontal sliders) and press the OK button. Use up/down to highlight "Date Stamp" and press OK. Make your choice and press OK. The date stamp will only appear on photos taken in the auto mode.
How do I date- stamp photos with my camera?
Enable the travel date option from Menu->Setup->Travel date. There are two options. SET and OFF. Choose set and exit the menu. Every picture you take from now on will display the date on which it was taken.
2helpful
2answers
When I print photos, it doesn't show the date on the photo. Also , when I scroll down to Date/Stamp on the menu, it is always "off". And I can't change the setting. Help
You haven't said what make/model your camera is, so it is hard to advise.
Without knowing the camera, I am guessing that you may be in the wrong mode when trying to change this setting. You won't be able to change it while reviewing pictures already taken. You can only change it for pictures to be taken subsequently. Once pictures are taken, you won't be able to add the date stamp, nor remove it if it has been stamped.
It may be that it won't allow you to set this if you haven't already set the date and time in your camera. I can't see why this setting would be shown at all if it was not possible to turn it on (i.e. if your camera did not have this feature).
Nov 03, 2010 • Cameras
Removing date stamp off pictures arlready taken
Turning the date stamp off will only work for future pictures you take...The only way to remove the date on the pictures you have already taken is to do a crop or photshop the area...
2helpful
3answers
How to activate time and date stamp on the pictures taken with olympus x-840
Well, not really a solution. More like clarification.
Olympus does not provide a date/time stamp on pics taken with this camera (f310/x840), so, no solution, just knowledge....
Date and timestamps
Is there a way to select a group of pictures on the camera and give them all the same date and/or time stamp?
No
Each JPG will show the date on which it was taken, but not on the photo, it will show it on your computer under the column "date picture taken"
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
