Televison & Video Logo
Posted on Jul 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Toshiba 32a33 TV, I have tried to program channels into the TV but it doesn't work. I tried to do it both manually and using the automatic channel tuner but it doesn't work. What should I do? It can't seem to find any working channels on either TV or cable. All it has is the white screen no sound.
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Jul 21, 2012
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006540
Points
237762
Either the tuner or the video IF stage circuit of your TV is faulty. Tuner has no repair, can be replaced as a unit. If the fault is with video IF stage, it can be repaired. But, both the work is skilled one. You must have through knowledge in electronics, and work experience to do this work.
4 Related Answers
A
Anonymous
  • Posted on Oct 14, 2007
SOURCE: TV's tuner will not recieve all channels
Since you are not using a set top box, you will probably only get channels up into the 70's, if available in your town, as most channels above this are digital, which analog cannot convert.  As for the digital tuner, I have the same problen.  It will not pick up any digital channels.  Because of this, I have had to get a digital box(why in the hell should I have a digital tuner?) to recieve digital channels.  I have the same tv you have, except a standard def.  If you ever find out why your digital tuner won't work, I'd love to know myself.  good luck, hope this helps.
Pookeybrain
Pookeybrain
  • 51 Answers
  • Posted on Nov 10, 2007
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Vista Electronics
  • 1694 Answers
  • Posted on Dec 11, 2007
SOURCE: no sound on channel 7
In audio menu, find selection for SAP and change to stereo...
Let me know if more help needed, provide Model #..........T.
Anonymous
  • Posted on Mar 31, 2008
SOURCE: sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
My Serial number is 94590994 and I cant tell what universal remote I need. TV is Stuck on channel 2
Do yourself a favor and save time, money and aggravation and locate an original remote, universals if they will program will be missing key features the original had.
If you insist on a Universal, use your computer and Google with the model number search for remote. that should give you a few hundred different remotes that might work.
My power light is blinking and the tv will not turn on. I tried unplugging it and plugging and it did not reset it self.
Try and used your remote to switch on or press channel buttons manually up or downshould come on .Thank you.
Hello; I have a Model 32A33 Toshiba TV with the following problem: 1. The TV was changing channels without pressing NO buttons. A student tried to fix the situation changing switches SA07 (Power On/off...
All you need to do now is to buy a new tact switch and replace all of them to resolve the issue. I'm not sure how it looks like the one installed in your unit but you may click this link to buy online. Watch the video below for more info regarding soldering and desoldering the parts on the board.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Toshiba 32a33. I'll be watching tv and the volume bar shows goes down to 0 (no sound) when it is in this mode the remote control will not work on the volume, you can get up and manually up the volume...
1st check to see if your remote volume down button is stuck. 2nd do you have wireless internet (router) or any other wireless devices phones,ceiling fans, another Toshiba remote, if so try unplugging them (or remove the batteries if it's a remote) while it's changing the volume one at a time. If a different device makes it stop try changing the channel on it. Also make sure the t.v doesn't have a mind of its own and remove the batteries out of the t.v remote, let it ride for a couple days if it happens without the remote being in play then you know your t.v is acting strange, if it stops then starts back up when you start using the remote again then you know your dealing with a remote issue. Sometimes Freq.'s merge causing remotes/wireless devices to conflict with each other.
Can get tv to work after hooking up to cable
Try using the input button on the remote's. and keep pushing it to see if it changes to a regular channel.. But first try turning on the TV switch on the TV.
2answers
Need to work menu on tv with out remote trying to get tv off cabl
Try using the Channel up and down to go vertically and the volume for horizontally.
2answers
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Took toshiba off comcast control and now ct-90157 won't work
We found the manual at home and was able to program the t.v. to recognize all the channels from cable and store them.
Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
