No obvious tear in door seal.Thank you.
SOURCE: Leaking washing machine - hotpoint aquarius 1100 - wm63
water leaks are very hard to locate as the water always drips from the bottom, it is just a case of detailed looking, after a while there will be a dry white mark where the water has dried out, this will show where the leak originated from, there are a few things at the front of the machine that it could be, sorry can't help much more nearly all parts can be bought by the public and with common sense and taking very detailed notes where wires came from etc, most jobs can be done by a competent diy person with basic electrical knowledge remember water and electric do not mix always unplug from power supply where working on any appliance
SOURCE: water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
SOURCE: hotpoint wf860 washing machine leaking
Had exactly the same problem and it did indeed turn out to be a blocked filter - mainly with "Colour Catcher" sheets. Initially I thought the dispenser drawer was faulty so spent twently-six quid on one before that failed to fix it and then I discovered this site!
To get to the filter, unplug the machine then remove the bottom plastic panel at the back of the machine (2 screws). Undo the jubilee clamp holding the black rubber flexible coupler that joins the drum, drain pump and pressure sensor to each other. Pull the black coupler downwards away from the drum. Inside is a plastic cup filter arrangement with a plastic ball. Clean this out of various debis - along with the sheets there was £ 2.26 (to put towards the cost of the drawer!) in mine.
SOURCE: replacing door hine on hotpoint washing machine
Its a ***** of a design. Mine is a Hotpoint Aquarius 1200 WD62. If you cant get the backing plate then get someone to tilt the machine right back and you can put your hand under to get it out. Then take the top off the machine(3 screws at the back). Then slide your soap tray right out,(put it to one side) you will then see 4 screws (Which hold in the other tray that holds the soap tray) take these out, you will then need to remove this white plastic tray to get your hand down the machine to reach the place were the backing plate goes. Once u have taken the screws out slide the soap tray holder to the left or right (can't remember) it will then come loose. You will then need to slide it back to lift it out the way (No need to take the pipes off the back of it) you may need to push the whole drum back at the same time you are pushing back the soap holder (Be gentle but it will come out). The holder should then lift up out the way, you can now get your hand down to hold the back plate on whilst you get a helper to affix the door. Make sure backing plate is on the right way, the screws will only go in one way (Check which way b4 u put it down into place). Then go backwards on all steps to put machine back together. This sounds like a load of **** but it worked for me and took about 15 minutes. Good luck!!
SOURCE: Water leaking from Door and Draw from Hotpoint Aquarius Extra
is the pipe were the water gose in clear it is leakiing by the door cus the water flows down the machine and own from the door hope this helps.
It is so common that water leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked from the front then the door gasket can be fault and needs to be replaced
please check this link:
If there is leak at the bottom as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
http://www.espares.co.uk/advice/washing-machines/a/7
