Can you connect to the Internet using the LAN cable?
Have you configured the wireless card in your laptop with the router's wireless settings?
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: Internet Explorer cannot display the web page
I've been having the same problem after I change my Aztech router to D-Link. I hope these can help you because my problem solved after doing it.
Go to Control Panel > Internet Options > Connections > LAN Settings and make sure you check the 'Automatically detect settings' option box and the other two boxes is left unchecked. Good luck!!!
I am having this issue. One laptop works the other not so much. I cant use IE. I can use and run AIM and Windows Messenger. CANNOT do anything else. Did all the ip renew release and all that ****. cant figure it out... Have an excelent conection but IE wont do its thing... [email protected]
SOURCE: trouble connecting to wireless network
Hello
You probably have a virus. To check for sure goto Start, Run and type cmd. Once the DOS screen pops up type ipconfig /all. If this shows data in all the lines (not zero's) then type ping Sony.com on the next line. If that comes back saying that Reply and then an address, this means that your actual internet is working fine and that your browser is infected or corrupted. If possible download the virus cleaner from www.avgfree.com and from www.download.com download malware bytes. You can download these at your local libray. Run these to clean your machine and then your browser should be fine. Also, get superantispyware from www.superantispyware.com.
Good Luck
SOURCE: purchased a 7in sylvania at CVS and although it
The WiFi software that is embeded into the OS does not work very well. Fortunately digitalgadget.com has a download that somewhat fixes this problem fairly well. The new download is not totally goof proof, but you can work with it.
Go to: http://www.digitalgadgets.com/netbooks/update.html and download the indicated update. You can copy it to a thumb drive and connect the thumb drive to your Sylvania , find it under My Computer and then copy it to your desktop and run it from there.
