Jamo SUB 200 Subwoofer Logo
A
Anonymous Posted on Jul 19, 2012
Schematic circuit sub JAMO sw 2010 - Jamo SUB 200 Subwoofer
1 Related Answer
Dennis McCollum
  • 137 Answers
  • Posted on Apr 20, 2010
SOURCE: Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
I want jamo sub 1810 circut diagram
Check out this link:
http://2getdtv.com/directv/stereo_receiver_codes.html?phpMyAdmin=ed9585cdc5a4551847999cb4dbcce76a
2answers
The fuse of Jamo Sub-200 gets blown off. is there anyone who might know the reason. thanks
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
1helpful
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
6helpful
Cant connect jamo sub 250 to marantz SR4001... how do i do it? any suggestions?
Use the PRE-OUT SW (subwoofer) output and connect it to the left RCA socket of your subwoofer.
Subwoofer problem
Sound like a component inside the sub is overheating. Most likely will need to be replaced.
Thanks,
Lee
2answers
I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
