Creda simplicity condensor dryer t622cw
SOURCE: Creda T622CW condenser tumble dryer drum wont turn
You need to check if the belt is o/k.
Remove top cover, and grasp belt, it should be firmly wrapped around drum.
If o/k, then could be a motor problem, or programmer fault
Once you have got the drum turning again, it is possible the filter light will go off,if not, then you have another fault
Hope this helps.
SOURCE: creda simplicity condensor dryer
You need to replace the door interlock or switch as it is better known.
You could spray inside the switch opening with WD40, before replacing switch, as it could be just sticking.
Please rate my solution.
Thankyou.
SOURCE: my creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
SOURCE: our tumble dryer is not
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
heatman101
