INTALLED A INTERMATIC TIMER AND EVERYTHING IS WORKING WITH THE EXPTION ON THE TIMER ITSELF. DO YOU HAVE ANY SUGESTIONS
1) First suggestion is for you to add a comment and say what model number Intermatic timer you are working with.
If this is a box timer, then model number shows on inside of door.
In any case, we are guessing at your problem without knowing model number.
2) If this is a box-type timer, main thing folks do wrong is reverse the line and load wires.
Line wires come from the breaker box, and Load wires go to the fan, light, motor.
Line wires have to be connected to the clock terminals or the dial will not rotate.
The clock terminals are usually visible as small white wires connect to two of the terminals. Again, this is dependent on model number.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
