Question about Xact Communication iVo XVP620 Skype IP Phone
My skype audio won't configure the ivo phone
Yes, the internet speaker phone. normally when i plug and play my other skype phone, it will automatically configure to voip. both speaker and mike
Where do you connect phone
If you want to use VOIP (voice over internet protocol), you'll need cable, dsl or faster connection, a router, and hardware to plug the phone into the router or a USB connection, such as that available through the Magicjack.
Skype and some others use your computer speakers and microphone, so you don't need an adapter.
You need to study the subject more before deciding what route to take.
Do a Google search on "voip products".
Dec 12, 2013 | Dell Studio Xps 8100 Desktop Computer
I cannot seem to hook up my mike and ear phones. I need help
Your headphone has two wires connecting to the head-speaker. look at where you will plug the headphone to your laptop. u will see two holes. first for audio(green code) the second for mic(other colour). make sure the same logo matches. this will work automatically. just increase the volume of the laptop.
Sep 13, 2011 | Skype IM
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Jul 07, 2010 | Nokia E71 Smartphone
VOIP 321 will not work with Windows 7
VOIP 321 is working with windows 7. Install the Vista Software. After that you change compatility under properties (right mouse klick) to windws vista and it works fine regards kurt
Sep 08, 2009 | Philips DECT VOIP-321 cordless telephone
When i talk using my belkin wifi skype phone i can here the other person but they cant here me well.
I think you need to have a look at your connection and see if it can handle VOIP traffic.
It sounds like you are downloading okay but your upload isn't good enough.
Run the tests at Dr-VOIP and it will tell you where you connection is falling down and you can either contact your ISP to have them investigate the problem or think about having your internet connection upgraded.
Aug 26, 2009 | Belkin Wi-Fi Phone for Skype - Wireless...
Vtec 7100 won't connect to skype
1. Unplug and re-plug the usb cable from the base station to your Skype computer.
2. Make sure Skype is running.
3. Re-install the vtech software (you can download it at http://www.vtechphones.com if you need to)
4. When Skype asks if it's ok to let it connect, do that.
Apr 04, 2009 | Vtech CS5111-2 Twin Phone
My Calisto Pro drops SKYPE calls
Did you install the PersonoCall software (bundled with Calisto Pro)?
Basically PersonoCall is the one in charge of handling all the VoIP applications.
Jan 19, 2008 | Lands Phones
Creative internet dect phone
what you probably have to do is configure it. there is probably an option to configure the two together. its like bluetooth you cant just turn it on and expect that it automatically works with your phone you have press buttons.
Dec 29, 2007 | SKYPE (683728017613)
Olympia VOIP Skype + DECT Phone
need Olympia PBNext OL2112 manual , can't set the clock ..thanks
Oct 19, 2007 | Olympia Lands Phones
Xact Communication iVo XVP620 Skype IP Phone Logo
35 people viewed this question
Top Xact Communication Computers & Internet Experts
Alun Cox
Are you a Xact Communication Computer and Internet Expert? Answer questions, earn points and help others
