SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
SOURCE: changing to multi region dvd
There are a couple sites I found that offer the codes for that player and the BD-P1000. I am not sure if I am allowed to post the links for those sites but the link to the site zimcloud posted is one of the places I saw it listed. You can google the model and region code and a list of sites come up.
Cheers
SOURCE: my blu-ray won't let me connect to netflix on
The photo you put suggests a Samsung BD-P1500 Blu-Ray player which doesn't appear to have Netflix Streaming built in to the player. Follow this link for Samsung players that do support Netflix:
http://www.netflix.com/NetflixReadyDevicesDetails?trkid=1473822&lnkctr=nrd-d-m-3-samsungnetworkblurayplayers&pdid=3&lnkce=nrd-d
SOURCE: CAN'T PLAY BLU-RAY DVD ON SAMSUNG DVD BLU RAY PLAYER
I have a Samsung BD-P1600 and was having similiar problem...played thru previews but would not play. Instead of just powering off/on... I pulled the plug on the ac cord out and left it out about 20 minutes and it now works !
Testimonial: "Thanks for responding. It's working!"
SOURCE: My Blu-Ray BDP1590 Samsung freezes at the title
Try to reset system at Samsung support. To do this you just take disc out, hold the FF button down on unit until you see "reset" then select language. Turn system off then hold power button for 15 sec. Then restart system.
As far as Netflix you got to got to system, determine if you are using wireless or cable. You have to set this yourself.
You should also update your firmware here at http://www.samsung.com/us/consumer/tv-video/blu-ray/blu-ray-players/BD-P1590/XAA/index.idx?pagetype=prd_detail&returnurl=
You will see a support tab, which has your download on it. I would try the CD based download first.Download the file, unzip it, and burn it onto a CD. Then, with the unit off, and unplugged, plug it in, open the drawer and insert the disk. Close the drawer and see if it will read the new files. If not, then try the same procedure on the USB option.
Thank you!
