Miele Novotronic G 841 Plus keeps stopping after a few minutes
There's a rectangular slot under the triple filter at the 12 O'clock position. The circulation pump impeller wheel faces you inside that hole. I would recommend using a special wrench for doing just that. The box wrench could get stuck and break off a blade on the impeller. I think Miele will mail you the special tool for free if you call them with the Model and Serial number. They say the pump seal inside there gets tight if it's not used on a regular basis and the hot water or the tool frees it up. I think they could use ceramic washers instead of rubber. They don't change size so there would be much less tourque required to start the pump.
