Question about Lowrance Hds 5 Hds5 Fishfinder gps Chart Plotter
Charting a route on water
I would like to know if the Lowrance HDS-5 chartploter will chart a course on water if I set up 2 waypoints or more or will it just show a strait line between the 2 waypoints. I have been able to set up waypoints but it just shows a straight line between them and does not take into account land masses or shallow water. I just had it installed and am trying to figure out how to use it. Thanks
  • 608 Answers
Hi, a waypoint is used to mark a point of interest for location purposes only whether it be for fish, hazards or a boat ramp etc. it is not intended to replace common sense. Your navionics card if purchased will show land masses, shallow waters, channel markers and known hazards. Regards Phil.
Posted on Jul 19, 2012
5 Suggested Answers
SOURCE:
  • 9 Answers
SOURCE: Trying to figure out how to start up my fuel guage on my Lowrance
You need to purchase a EP 60 fuel flow meter. Once you have it installed in your boat, you need to monitor it. You set it up under NMEA DEVICES on your setup menu,
Posted on Jun 24, 2009
SOURCE: lowrance x135 not functioning properly
Had the same issue with another brand. Turned out the transducer cable was picking up noise from other cables (power, trolling mtr. etc). Try moving the transducer cable away from any other cables. I put the cable in a 1/4 " plastic housing up to the point where it was above deck and it stopped all the strange stuff. Not sure about the temp issue??
Posted on Jul 21, 2009
fishdoctorfi
  • 178 Answers
SOURCE: Can I use my existing transducer(1000 watt tilted
As long as the connection is the same.....maybe. The difference will be the angle of beam from boat to bottom. May not cover the same area...or you could loose zoom etc. something will be different.
Posted on Dec 27, 2009
Editor925
  • 285 Answers
SOURCE: How does my Lowrance HDS-5
To connect a LRA 2400 to a Lowrance HDS-5 sounder/chartplotter, you can run an ethernet RJ45 cable from your Radar Processing box to the HDS-5 unit. You will need an adaptor cable for the RJ 45 cable to hook into the HDS-5 head unit. This is part no 000-0127-56.
As for the different transducer pinouts, I am not sure what transducer you have now so I cannot say if there is any kind of converter plug available, however, the HDS-5 units do seem to run best using the transducers that are made for them. Your best option may be to buy the transducer that is made for them, and this will directly connect to the display unit.
Hope that helps!
Posted on Mar 11, 2011
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
How do I program my lowrance to locate reefs if I have the lat log reference?
You can go to your GPS page and zoom out and then using your cursor pad and move your cursor so it is in the general area of your coordinates. Start zooming in andifferent as you do the the lat, long readings on your screen will become more precise. Continue to adjust your cursor position so the coordinates match up with known position you have. Continue until the cursor position on screen and your known coordinates match.
Push "ENTER" twice. Your way point will be saved at the current position of the cursor.
OR
Push your cursor pad to bring up your crosshairs on the GPS screen. Save that waypoint, then go in and edit the coordinates to match your location data and save it. The waypoint you created will move to the new coordinates.
Aug 10, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Problem with st1000 trying to go wrong direction using hds5
One of the settings is 180 degrees off. Go back through the manual and check all of your setup settings. I had that happen once to me.
Dec 03, 2013 | Lowrance HDS 5 Fishfinder GPS Chart...
Just updated to the last version 4 of firmware. Depth reading are wrong, say 48 meters when it's only 2 meters.
Check for depth offset, there may have been an unintended change that altered this setting. This setting compensates for draft....
Jun 21, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
How can I learn more about using my debth finder. Its new to me . Any video tutorials or materials I can read or watch?
look under support
http://www.lowrance.com/Products/Marine/HDS-High-Definition-System/HDS-5-FishfinderGPS-Chartplotter/
Feb 08, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
Lowrance Hds 5 Hds5 Fishfinder gps Chart Plotter Logo
191 people viewed this question
Top Lowrance Boating Experts
Bob Peloquin
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
