Which one is the VIN?
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Volvo servicecentre and get them to enter this code for you.
SOURCE: volvo car radio
i used to sell volvos . I believe if you call volvo serice usa , give them the vin # and identify you're the owner , they should help you.
SOURCE: I have a volvo S40 Diesal, HJ54 registration and
put an aftermarket radio in your vehicle. in dash changers are **** anyway. if you can find a car audio repair shop, they may be able to remove your cd's for you.
Testimonial: "Thank you I will give it a try"
SOURCE: looking for radio code for a volvo s40 t4 ser:
Unfortunately this is a MITSUBISHI radio fitted into your Volvo and the code can only be obtained from your VOLVO dealer or by using a Radio Decoding Service
SOURCE: I have a 2000 VOLVO v70 and i need the radio code
The Volvo SC-816 radio is made by MITSUBISHI and iunfortnately the code will only be available from the Main Volvo Dealer or a Radio Decoding Service
