I met the same difficulty for the previous period,and I know the easy
an effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from http://www.windowspasswordreset.net and install it on other unlocked computer.
Tip2:Burn Windows Password Reset to CD/DVD or USB.
Tip3:Insert newly created CD/DVD or USB to your computer which you forgot its password and reboot it,and follow the instruction that follows.
I hope it can help you soon.
Windows admin password lost is a normal thing nowadays. The important thing is which way you will choose to change the lost password and how do you change it for your computer's data security. Reset disk can be recommended firstly, because it is quick and easy. If you have no one your second best choice will be reset software. Windows Login Recovery can be as an example. Windows Login Recovery Secure Windows Password Recovery Tool
Windows 7 admin password forgotten is a normal thing nowadays and many ways you can choose to unlock. If you have a reset disk you can use it crack directly; if don't have, you can create one by yourself with blank DVD/CD or formatted USB flash drive. To create one you can download Ophcrack or Anmosoft Windows Password Reset. But personally, I strongly recommend Anmosoft, which is more effective and safer and you can learn more from:
http://www.resetwindowspassword.com
Windows Password Reset Software
Here is a guide to crack Windows 7 admin password with Windows Password Recovery Professional.
Step1: Download Windows Password Recovery Professional from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD/USB to burn Windows 7 password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD/USB.
Step5: Start to remove Windows 7 password with the burned disk.
Step6: Reboot computer and login to the locked PC without password.
