Cranks good idles good but will bog sometimes at full throttle, I see no adjustment screws or any place they could be. There has to be a way to adjust this. Any ideas will help thanks.
Check these out...
And...
And one more...
Do you have two adjustment screws down in a hole in the carb?
If you do they are the carb. high and low adjustment.
What I do is take a hacksaw and cut a groove right in the housing an the screw heads .that way you can adjust them Good luck
Could be a couple of things... like possible clogged filter air or fuel...what's the condition of spark plug???
plug new filter is new foam filter we had it tuneed and new line put in it in march this year i use the can fuel due to what the ethonal will do to the fuel lines. Hope this will help.
If it cranks good , that rules out the spark plug. cause a bad plug it would be hard to start same with a dirty or clogged fuel filter, and what we were asking and I guess It is my fault for not makeing it easer to understandis. How do you adjust the carb. but now we know it takes a 5 mm female hex driver to turn the adjustments. Thanks every one.r
just found out about the adjustment screws they are these black un sloted pins you have to use a small plastic ink pen barrel to turn them thanks RAy
