I agree wiht chris,that's a great solution.
What about tape to pc?
SOURCE: Lanier tape dictation machine
Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
are the Best
SOURCE: Voice recognition using Sony ICD-P320 and Naturally Speaking
I would run compatibility check. It sounds like not compatible with Vista.
SOURCE: I own a Lanier
1. Your device possibly has a broken voice connection from the dictation microphone or the record heads need cleaning.
It sounds like there is an intermittent connection between the dictation microphone and the recording heads.
2. Your unit will need to be serviced by a tech. This may require dis-assembly and and rewiring of the microphone. This is an intrusive procedure.
Hello the alarm that you are listen is the end of the tape alarm the reason it detect a fast motion and is warning you that the tape is almost to the end but if you don't agreed that the tape is almost to the end your unit needs service you can Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
