While on my iPad (original) all the sudden, it goes black screen, powers off. I must restart to continue, sometimes it will shut down several times then, other times it may work all day without shutting down by itself. Every time it shuts down, I perform a reset. It happens again. When it shuts off, I don't necessarily have to be doing anything, may be reading an email for example. I am unable to find any information on this occurring with others. Thanks for your assistance. Bill
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
SOURCE: Looking for an Ipad Manual
http://manuals.info.apple.com/en_US/iPad_User_Guide.pdf
Testimonial: "Thanks a lot, that's exactly what i was looking for, Thanks FixYa and thanks the expert!!!"
SOURCE: How do I set up my work email on the ipad
Does your work email supports a POP3 or IMAP settings?..I fyou do you just need to know what is the incoming mail server and outgoing mil server. Do not forget to ask for the ports needed in order for the settings to work with your ipad.
SOURCE: all of a sudden the icons are too big and don't
I believe that you may have the accessibility mode turned on. I think if you double tap with three fingers it should return to normal.
SOURCE: I have just got an
You will need to setup a Exchange mail account on your ipad to receive all the mail and calendar items that you see on your Outlook mail and calendar.
Here is how to add an exchange account:
. From the Home Screen, tap Settings
2. Scroll down and tap Mail, Contacts, Calendars
3. Select Add Account > Microsoft Exchange.
4. Now type into the following information:
* Email: your email address
* Username: your-Exchange-User-name
* Password: your-mail-password
* Description: It's Optional
* Server: ****.com
For your username, and server names, you will need to contact your company's IT department for the credentials. But your username is the one your IT dept. gives you for email access and password. exchange server name is the server address to access your mail.
SOURCE: iPad replace broken screen
the only thing that i can be sure that would help is that you need to call the manufacturer and get a screen replacement because since the ipad is fairly new it wont have many guides or anything that can really fix a broken screen.
i hope that this can be useful
Charley Brown, Please forgive my delay in answering your solution, I was called out of town for a couple of days. And unable to get to the internet. Yes, My reset was with the home and power buttons, which I had tried two or three times with no success. However, your solution to perform a factory restore seems to have corrected the shut downs. So far today, it has not shut down once. Please except my sincere thanks, Bill
