Lenovo 3000 N100 Notebook Logo
Anonymous Posted on Jul 18, 2012
Chatging problam in my laptop
Charging problam .
Friendly PC Repair
Level 3:
Genius:
  • Lenovo Master 1,274 Answers
  • Posted on Jul 19, 2012
Friendly PC Repair
Lenovo Master
Level 3:
Genius:
Answers
1274
Questions
Helped
262084
Points
3736
What's teh problem.... if it won't charge make sure the charger is functioning properly. get a multimeter and check the output voltage.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
My sweeper turns off after 30 seconds. How long must the battery be chatged so It lasts longer?
how old is your sweeper? If you have not kept the battery charged you may have killed it. You should keep batteries charged up so they last. i keep my batteries charged up all the time even my cordless drill. i found if you don't you have to buy batteries all the time.
Good alternator not chatrging in my 1984 gts celica
if its a good alternator then the battery must not be holding charge ,or you have a drain on the battery ie interior lights left on.What is the alternator chatge rate ? should be at least 13.25 volts
I am new at this i plug in c harger and only powre light comes on, is it charging or is the chatge light supposed to come on?and how long does it need to charge a jazzy select?
If your charger has a red and a green led on it when the green led lights the battery is charged. If you use it a lot during the day it may take 8 to 10 hrs or more to fully charge the batteries
4helpful
3answers
How to charge a zebronics node mp3 player
Hi Sudarshan
It is charged through USB. Plug it in to a USB port of Laptop or Desktop or connect it to a USB Charger. Make sure that you do not drain the battery completely. When discharged do not keep it without recharge for a long duration . .
Hope this will help you
1helpful
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
The red light above the chatging plug stays red when I am charging the computer. is it supposed to be this way?
Try removing the battery, hold the start button for 10 seconds, then reinsert the battery.
Plugged in not chatging
Need to test if power adapter is providing power - easy to do with multimeter. If no power, replace power adapter. Replacements found easily online and not very expensive.
IF power adapter is working and putting out power, either you have a damaged power jack in the laptop, or a worn out battery that will not accept a charge. Power jack replacement is best left to experienced technicians, battery replacement is simple and replacement readily available online.
1helpful
My ds wont chatge
You need a replacement battery... You can buy one online or call nintendo and they may send you one.
How i m able to listion voice both of my builtin speaker laptop
use the volume control and put everything in the middle
Laptop not charging (Presairro C500)
Need to order for my Lap top Recovery Disk Need Phone No
my EM- IS Frances Lovegren lovetko8@fairpoint
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
