Led screen says CHR what is this on Nikon d-70 I have a wedding in two days! Please respond [email protected]. Thanks!
SOURCE: nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
SOURCE: Error CHR in D70s
AS AN EXPERT I WII SUGGEST TO OPEN CAMERA SEPERATE THE CF CARD SLOT THERE COULD BE DRY SOLDER ON ANY OF CONTACT PINS,OR DUST ON THE PINS OR FPC CONTACTS GOT SLIGHTLY BLACKENED AT THE POINT OF THEIR RESPECTIVE CONTACTS(DENTS).GET THEM CLEANED,REFIX& SEE YOU WILL NEVER HAVE THE PROBLEM FOREVER
SOURCE: problem with Nikon d90
unlock your card.
you'll get that message when the SD card is locked.
Lock the card only to prevent deleting photos from it.
good luck!
Alberto
SOURCE: Nikon D 70 issue
If you lost the manual for this camera can be downloaded from Nikon directly <a href="http://www.nikonusa.com/pdf/manuals/dslr/D70S_en.pdf" target="_blank" rel="nofollow">here</a>. The error message is discussed in detail on page 200. The CHR error you're seeing has to do with the memory card. It may be a simple as: it has no more free space to record more photos, or the card may not be formatted, or is damaged. Consult the manual for more tips and worst case, try replacing the card with a new one. Format it and try again. Good luck!
