Noticed leaves gathering at the bottom of my pool and suspected the pool sweep was not working. I turned on the pump manually and though it started initially it shut off shortly after. I cleaned my filter and tried again with same result.
Part number on pump is 7-173840-23
CAT B625
Make sure that the feed hose floats are properly attached and spaced. Make sure that the opening at the end of the sweep hose is not blocked. You might also need to adjust the power to the pool cleaners sweep hose. To adjust the motion, turn off the booster pump and turn the sweep jet clockwise to increase motion.
red valve handles align with flow of water long ways the tail in direction of pipe valves open to open pool generally all Valves open Main drain (floor of pool). Skimmer square hole somewhere on side edge of pool... There could be a third Valve for a seperate Vacuming port (like mine) it can be either its below water line .. On the Round Sand filter theres a Multi port Valve I usually start the Filter in RECIRC mode .. While I net and gather debris then I add floculant leave on recirc two hours . Then Shut ALL down for 12 Hrs while all the algae and debris sinks to bottom . Water will be reasonably clear.. Make sure pools Extra full , And Vacum all on bottom on waste setting
A pump motor running without any flow of water is one of two things. The impeller inside the pump that is connected to the motor is broken or clogged. Open up the pump and inspect the impeller for debris or seperation and clean or replace as needed.
Problems with the sweep hose on these pools cleaners usually just means that you need to do some fine tuning. Start by trying to adjust the sweep hose adjustment screw. To adjust, turn off the booster pump and turn the screw clockwise to decrease motion and counterclockwise to increase. You might also need to replace one or both of your swivel ball bearings (part #D20).
Make sure that the opening at the end of your pool cleaners sweep hose is not blocked by the sweep hose scrubber. If this does not work, you will need to adjust the sweep hose screw as mentioned above. The only thing that I would add about that is to make sure that you turn your booster pump off before you make adjustments. Hope this helps! I have a copy of the users manual for this model. Let me know if you need it and I can give it to you.
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
