Televison & Video Logo
Posted on Dec 12, 2008
Lg tv 52sz8r-tb new lamp installed, red lamp light still on
Recently replaced lamp for lg tv 52sz8r-tb because lamp life over error was on screen, now after replacing lamp red lamp light on front panel of tv is on all the time
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1084
Points
5
You need to reset your lamp hours timer. as far as i know this can only be done with the service remote
  • Anonymous May 03, 2013
    whats a service remote and how do I get one?
1helpful
On screen message "lamp life over, error!!, which
Hello John:
If you replace the DLP lamp out of your Zenith or LG, you will need to reset the counter...otherwise you may get an annoying reminder every few days if you're surpassed the predetermined hour mark.
To Reset:
Ensure the TV is powered on.
1) Press and HOLD the MENU button on the TV
2) Press and HOLD the MENU button on your REMOTE
(hold both these until the service menu pops up 5-10 secs max.)
3) Let go of the REMOTE button first, then release the button on the TV
4) Press and HOLD the ENTER (or OK) button on the TV
5) Press and HOLD the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
6) Let go of the REMOTE button first, then release the button on the TV
We suggest writing your lamp hours on a piece of masking tape and taping it to the back the TV for future reference.
7) To reset the lamp counter, press SELECT (or the button in the middle of the direction arrow buttons). Hit SELECT a second time to confirm clearing the lamp counter
For certain models, you might have to tweak these steps slightly...
2answers
My LG projection tv (serial number 52sx4d-ub) won't turn on, an orange light flashes then turns red. How do I know if I need to change the bulb or the ballast? And how much does it cost to change the...
Orange blinking light under a small picture of a light bulb? Then turns to a red light?
Sounds like the same problem I had when I picked up my LG 52SZ8R. After replacing the lamp the TV ran fine.
Easiest way to see if the lamp is the problem is to take it out, and look at the peice of wire in the globe as you would an old light globe.
If you need help, download the following manual, and look at page 9.
http://www.jordansmanuals.com/ServiceManuals/LG/TV/PROJECTION/62SX4R/62SX4R%20Service%20Manual.pdf
If it does come down to you needing to replace the ballast contact: http://www.statewideapp.com.au/index.php?selectedContent=1188381775
They should be able to give you a quote and part number, if you don't like their quote you can always use the part number to search for one thats cheaper.
I have a LG 52 inch model number 52SZ8R-TB but no longer have the manual. There are 3 red LED's on the front panel, the right one flashes red whenever I try to turn the TV on. Does anyone know what this...
YOU CAN REVIEW THE MANUAL FROM THE FOLLOWING LINK.
http://www.lge.com/au/support/product/support-product-profile.jsp?customerModelCode=52SZ8R-TB&initialTab=documents&targetPage=support-product-profile
4helpful
2answers
How do I reset the lamp life on my LG 52SZ8R.
hold the mute on the remote and press enter on the tv and it will come up in the menu for you to reset
9helpful
2answers
How to reset the lamp timer count on a LG rear projection TV
1. Press the OK or enter button on the front panel and MUTE
button on the remote control simultaneously (About 5 seconds).
2. Press the VOLUME (>) button.
3. Press the OK or enter button.
Lamp time will be reset.
Resetting lamp hours
No its not correct this error message is telling you your lamp is going out and pruchasing a new one will reset this otherwise you have to cut some wires! i would not recommend that!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2helpful
Reset globe meter
Press ok on the TV and mute on the remote at the same time about 6 seconds) to bring up the rest menu
I have a LG 52SZ8R-TB DLP TV. I have recently had to replace the lamp. I ordered this through a certified LG repairer. Upon fitting the new lamp the TV appears to not be light enough. It is that dark I...
We had the same problem. One place changed the lamp but they couldnt work out why it was red and lots of shadows. Next mob said that it was the component so they replaced that. From the 28/4 till end of Oct, the TV has now switched itself off and wont come back on. Both places say its the lamp - however I cant see how in 6mths it would run out again. The people who replaced the lamp dont want to help, just said they will put in a new one at $521. This TV has cost us so far $1100 in repairs and it's only 3 yrs old. Not happy. The DVD recorder broke within the first year, the set top box broke in the 2nd yr and the surround system blew up (yes smoke appeared and we were lucky we were home) on the 13th month. Mind you our LG comp screen also shut down on the 13th month. Never again will I buy LG
3helpful
4answers
Lg llp xg22 lamp reset
These instructions are taken from page 44 of the User Guide.
Turn the power off but keep pluged in. Press the buttons on the control panel in the sequence as below.
Press "Up Arrow", Press "Down Arrow", Press "Left Arrow", Press "Right Arrow", Press "Menu", Press "Enter".
Lamp time will be initialized
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
