My car won't start. It doesn't make a sound when I turn the key. My lights work but my radio doesn't. It just does nothing.
Any real answer yet? did the problem ever get resolved? i have the same problem with my sister's car. too cold to diagnose tonight, but will post the solution probably tomorrow. since the lights and heater works, but ignition and radio arent getting power, my first guess is there's probably a fried fusible link which controls the 2nd accessory power to the ignition switch. will post a solution soon.
SOURCE: 98 plymouth breeze wont start turn key to start
make sure battery connections are clean and tight . make sure battery is good and fully charged, chek all fuses.
SOURCE: can not find the
The starter will be on the driver's side of the vehicle, and you can trace the positive cable from the battery to the starter. It will be where the engine meets the transmission.
SOURCE: 1998 plymouth breeze
alrite i thought myself to first check the connection in the steering wheel which is easy to do all you do i just pull of the front cover.... or to check by the front grill and look for the horn so i figured id do a lil research and found to check the junction box
SOURCE: I have a 97' plymouth breeze all the lights work
Could just be a bad sensor? or maybe a connection issue with cables,corrosion, etc....... Pepboys will hook up test computer and give you a free diagnois code to reasearch problem or you could take the code and give to your mechanic to save on additional costs of testing at shop.
