I have seen your comment that you fixed a paper jam by aligning some stuff of scanner and printer module. Could you please be more specific?
I have maybe the same problem...
Paper is stucked just after it is taken into the printer. It is possible to remove it. If I slightly push the paper (it requires precise timing and pushing power) the printer prints. So there had to be some slight blockade there...
Till now, it was a perfect printer!!
SOURCE: Samsung CLX 2160 "paperjam2" problem
Hi ...
IN CLX 2160, paper jams usually occur in three areas of a printer. The following error messages indicate the area in which the jam has occurred:
Your error shows paper jam2 but i am giving you directions to fix the paper jams indicated by each error message so that you can handly any kind of paper jam issue with your printer.
Paper Jam 0
When your printer displays Jam 0, paper has failed to pass through the first sensor.
To remove the jammed paper, follow these steps:
If your printer still displays Jam 0 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 1
When your printer displays Jam 1, the paper has failed to pass through the second sensor and has jammed around the toner cartridge.
If your printer still displays Jam 1 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 2
When your printer displays Jam 2, the paper has failed to pass through the second sensor and has jammed at the fuser.
If your printer still displays Jam 2 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Please vote if this helps ... Cheers :)
SOURCE: Samsung clx-2160 says waste tank is full. What
If you open the front of the printer then you will find a waste tank in the left side - its gray. Take it out and empty it, and put the tank back in place.
This works for Samsung CLX-2160
SOURCE: I have a samsung CLX 3175 FW printer. Paper jams
The limit switches are just flags that block or unblock photo sensors. Try blowing the printer out with some canned air, paper dust on these sensors is a common cause of these problems.
Testimonial: "Thanks very much, I'll try that - I'd like to think it was as simple as that! Kind regards Ray"
SOURCE: I need to reset the transfer belt counter
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
I have the same problem, help please!
