The other control buttons don't work. When I power on the treadmill, it raises to the maximum incline and then goes back down to the botttom.. never stops until I pull the red magnet.
SOURCE: Image 17.0 treadmill is stuck in incline position
Hello there, The first thing I would try is to calibrate the incline on the unit.
Do this using the following procedure.
With the safety key out, press the stop button along with the speed up button while inserting the safety key onto the unit.
remove your fingers from all buttons, Then press the stop button one time. Now press the incline up button one time.
The unit should go all the way to the top, then return to the bottom.
Remove the safety key and reinsert it to continue using the machine
If this does not work you can manually move the machine to the bottom using this procedure.
Remove the hood cover b removing 2 screws in the rear of the machine and removing the first 2 screws on the foot rails on each side.
You can now lift the cover out of the way.
At this point you will see the incline motor located in the center of the unit pointing in a downward direction.
On the top of the motor there will be a small fan encased inside of a metal cover. There will be a flat head screw located inside the metal frame where the fan is. Rotate this clockwise to lower the unit. (the motor is geared very high it may not seem as though it is moving but it is) be patient that procedure does take a little while.
Any questions please feel free to leave another message on this link.
Good Luck! Tim
SOURCE: My treadmill's incline goes up and down but the
The motor controller. If everything works but the belt will not turn, that's 99.99% your problem. I can get you a controller and walk you through replacing it. [email protected]
SOURCE: Image 10.0 treadmill incline not working
I have a image 10.0 treadmill. I recently started running on it about 2 weeks now, my problem is that now when i put the red plastic card in the console to start it up, the console completely lights up and starts to buzz, and i won't start. I've unplugged it, it worked, then when i shut it off again and reinsert the red plastic card it does the same thing. What is this problemand what can i do?
ERR1
indicates a speed issue. In this case, the motor speed as reported
from the optic sensor differs
from
the speed setting.
Analysis:
Optic sensor signal issue -- Either the optic sensor signal is not
right, or it is read incorrectly, or
the
signal is not reaching the display.
clean the speed sensor, test for open or faulty. tight the connector very well. RUN the software calibration for easy troubleshooting and fix it.
see the diagram attached. and follow steps.
God bless you
Version:1.0
StartHTML:0000000168
EndHTML:0000003648
StartFragment:0000000468
EndFragment:0000003631
The
Steps for Newer Style Console Calibration
Locate the calibration area on the
rear or underside of the console (a hole, near the console's center,
that goes through to the electronics board. (This hole should not
have a screw in it.)
Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click
when pressed).
Press the button 2 times
(with the pencil eraser). The first click should show CL11
in the console, the second click should show CL21.
If the process was done correctly,
and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons
on the console and observing settings. This will not require
any other tools.
Press ENTER. CL22 should display
in the TIME window and (??) in the SPEED window.
Press ENTER. CL23 should display
Press ENTER. CL24 should display
Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
Press ENTER. CL26 should
display in the TIME window. You should then see the
letter "E."
Press ENTER. You should see "SS"
or "55" in the console.
Push the STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill.
Push the ENTER button. The walking
belt should start to move, accelerate to maximum speed, then stop on
its own.
When the belt stops, the
incline should self test by raising to its highest
incline position, then lowering back down to its lowest
position.
Once the incline test is complete,
push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
The Steps
for Newer Style Console Calibration:
when pressed).
any other tools.
letter "E."
treadmill.
its own.
position.
Based in Austin, Texas, Jolie Johnson has been in the fitness industry for over 12 years and has been writing fitness-related articles since 2008 for various websites. She received her Bachelor of Arts in English and philosophy from the University of Illinois.
By Jolie Johnson, eHow Contributor
updated April 15, 2011
The NordicTrack is a treadmill designed for in-home use. It offers a speed range of 0 to 10 mph and an incline range of 0 to 10 percent. It folds up vertically to save space when you aren't working out and can be rolled to a different room. The console has 16 preset workout programs and features iFit interactive technology. If you have problems with the console or walking belt, you can often fix them yourself with some basic troubleshooting steps
Instructions
