Bought new motor need to know how to place the fly wheel so it will be properly in time
SOURCE: Need diagram of vacuum system for 1988 jeep comanche pick-up 6 cy
Haynes manual has a diagram. Main important hookups are to power brake booster, fuel pressure regulator and map sensor. also need a connection to a/c controls inside drivers compartment and evap system canister. will also need connection to egr valve solenoid if you have one. as well as pcv on valve cover (or ccv which replaces pcv on some)
SOURCE: 87 Jeep Comanche, turn signal issues
You will find that there are two flasher units on the fuse panel. Turn on the four ways to identify which flasher serves that circuit. Then, move the flasher to the other position (where the signal flasher is) Your directionals should then work. You then can buy another flasher and install it when you have a chance, putting it in the 4 way position. The 4 ways get used so infrequently, you always have a reliable spare signal flasher there!
SOURCE: Can I drive my 1994 Jeep Cherokee on the highway?
Yes you can drive your jeep on the highway, no you do not have shift on the fly capabilities.Vehicle must be stopped to engage four wheel drive, otherwise you will grenade your transfer case, and you will not like the repair bill that comes with that....at all.Any other questions get back to me...I'M HERE TO HELP!!!
SOURCE: 87 jeep comanche blinkers, wipers, a/c and horn don't work
Check the fuses,and then look at the fusible links,most likely on the starter,if they are good,replace the ignition switch.
