The model name of your Nokia mobile would be behind the battery not on the battery. BL-4C is the name for Nokia mobile batteries. It cannot be restricted with a code. Find out your Nokia model and get the restriction code from www.Prounlocking.com at affordable cost with easy unlocking guide. This site is a trustworthy source providing accurate unlock codes at affordable cost.
SOURCE: RESTRICTION CODE NOKIA 2630
Try unlock.nokiafree.org/ or tryckill.com for free unlock codes.Other wise contact O2
SOURCE: I need the restriction code for a Nokia 3500 cb
http://www.askstudent.com/hacking/how-to-unlock-any-nokia-based-cell-phone-and-get-its-unlock-codes-absolutely-free/
SOURCE: Need restriction code for opening Nokia BL-4S Please
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try these WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
www.unlock-free.com/nokia-master
The IMEI number is unique the each mobile phone.
The number is printed on the label under the battery.
You can also get the IMEI number by entering this on your phone
*#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
SOURCE: i need nokia 6303c restriction code vodaphone
You can get the restriction code through online..........i will suggest the website http://www.unlock-zone.com/ which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
