SOURCE: not charging battery no power on stator wires?
With engine off, check continuity through the stator winding. you should have continuity both ways if testing before the diode. If testing after the diode, and you still have continuity both ways, then your diode is blown and needs to be replaced. If you don't have continuity through the stator windings, then stator is defective.
Some models have a fuse in the charging circuit, look for that as well and test with a meter, don't assume visually.
SOURCE: electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
SOURCE: I have a Kohler CV15T engine on a walk behind
go to kohler.com and you should be able to download a free service manual that has alll the wiring diagrams and lots of other helpful info.
