1 year old Amana AFD2535DES French Door Refrigerator stopped cooling in Refrigerator section, although lights still work, and freezer still works. Started in last 12 -24 hours. Ice maker fine. Cold water dispenser not working. We can hear the fan working. No dust clogging compressor. Any ideas?
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Amana refrig model # afd2535due. Evaporator coil freezes over which cause top refrig air to stop circulaton and compartment temp get warm. Act like it not defrosting?
In my case, the fan is running. I turned off power for more than 3 hours today. However, when I turned power on, the same problem - the refrigerator is not cooling but the fan is operating. I removed the lower panel on the top shelf. it is open. Any ideas?
Thanks for help!
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Solution arrived.
The whirring sound we heard was the compressor, not the fan. The variable speed fan was kaput - 1 year and 2 weeks after our purchase = no warranty. New fan, new thermostat, and we are back in business. Fan should not have failed, but repairman says they use planned obsolescence parts.
JENN AIR - PROBLEM IS REF NOT COOLING, FREEZER IS OK ,ICE MAKER IS OK. FAN IN LOWER BACK IS NOT RUNNING.
I had the same problem. Could you let me know how to fix this? I really appreciate your help!
Zhiming ****,
I have same problem as you. Fan in back is working, as is freezer, but food section not. Did you ever get a solution for this?
thanks,
Dennis
amana refrigerator water stopped working
freezer cold but refrigerator warm. starts to cool but stop in seconds.
amana AFD2535DES is making a clicking soumd and does not get cold
LG LFX25971ST
LG LFX25971ST
the pilot lamp is on when the door is opend, but the refrigerator is not on compressor is cold seems like there is no power going to it
not receiving water
Bottom coils are moderatly dirty.
do you think it went into defrost mode if so how can stop this
