I've only had this headset for about 2 months and now the white on/off indicator light won't turn off. At first it would charge and play anyway, but now it won't turn on at all. It appears to have a full charge and the white light is on but nothing happens when I try to turn it on so I'm unable to try to reset it like the manual suggests.
SOURCE: hbhpv708 when i press any
Hi, Before any bluetooth will connect to any phone, the red or red and blue light must flash back and forth. Make sure you're phone is in the set-up mode to recognize the phone. The easy way to do this if you dono't have directions, is to get the name and numbers off of the bluetooth and go online to find it. It will walk you through the steps to connect it to your phone. I have done this with many different models if all else fails. Give it a try and let me know what happens. This will solve you're problem,
Shastalaker7
SOURCE: Master reset HBH-PV702
How to restart my hendsfree? pls answer me, i can connect it with no one
SOURCE: bought a sony ericsson bluetooth
To turn this headset on you simply press and hold the Call Handling Button for 5 seconds. If it turns on it will make a beeping tone and flash green.
SOURCE: i have a HBH-PV705 bluetooth headset that is
I am having the exact same problem with my PV705! I've followed all the directions and tried charging it numerous times but still nothing.
SOURCE: My Sony Ericsson Bluetooth headset
www.sonyericsson.com/.../HBH_PV703__UG_R2a_EN_DE_ES_FR.pdf
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Start with the headset powered on. Press and hold down
the call control button while also rotating the multi function dial
upward (away from the light) until the indicator light on the headset
starts flashing red then green. When prompted for passkey, enter
0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter
(discontinued): Turn the headset on and the adapter off. On the headset
push in and hold the mute/volume dial until the indicator light begins
to flash. On the adapter press and hold the blue power button for 10
seconds. The light on the adapter will flash once after 3 seconds-
continue to hold the power button for another-7 seconds until the
light flashes red. If the pairing is successful, the headset will
sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued):
If you remove the battery cover from the headset and then remove the
battery itself. On the Green PC board itself there will be a letter
followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Hi! I am having the same problem ironically after the 2nd month. Have you fixed it yet?
