I just purchased a used MPK-10CR portable AC unit and the previous owner did not have an instruction manual. Also several fan blades are broken off so I need to find a new squirrel fan cage.
You can find the Use & Care Manual for your Everstar MPK-10CR here:http://www.supportuscenter.com/documents/MPK_Manual.pdf
The warranty & repair services for this unit are handled by Midea. I would suggest contacting their staff for the part.
Contact for Technical Service USA:
Contact Person: Winston Sankey
Tel: +1-305-591-8460
Fax: +1-305-591-8451
E-mail:[email protected]
I also did a search for you on AppliaceFactoryParts.com. This may be the part you are looking for:http://www.appliancefactoryparts.com/search/part/1371698/146072
Best of Luck!
SOURCE: need owners manual for Everstar Portable AC
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
SOURCE: need owners manual for Everstar Portable AC MPM1-10CR-BB6
Here's the 34 page manual from Danby Canadian website. =>
http://www.danby.ca/cms/uploads/products/en_manual/DPAC8020.pdf
Please leave feedback. Thanks.
SOURCE: Compressor does not work
Empty the water tank, located at bottom of unit either left hand side or right hand side, normally removable.
all the best
SOURCE: My Everstar MPK-10CR portable 10,000 BTU's is blinkink P1 all tim
Make sure the level arm is also making good contct with the water bucket when you insert it. You can awlas pull the level towards you to adjust for better contact.
