Before with the bulb the screen would go blank and come back on after a couple seconds. Now with the new bulb installed we have no picture at all and the fan is not working. When we cut it on the green on button turns into a red blinking light. We have our TV set up on a DVR so we have sound just no picture. Please help!!
SOURCE: Blinking Red Power Light
It sounds like the horizontal (H stop) and vertical (V stop) has gone bad. Check Cap 515 and 516. IC1509, Q1505 and the jungle IC, IC206. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC.
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
SOURCE: HELP! KDFE55A20 watching TV and screen goes black and loses sound
Yes, its most probably lamp issue.
Please but original Sony lamp from Sony store and replace it in TV.
SOURCE: Sony KDL-46V3000 Bravia LCD Black screen
Please count Sony KDL-46V3000 standby light blinks as there would be interval of 3 seconds between blinks. Let me know how many times light blinks as its an error code.
