I changed the connection back to the right hook up could my starter bendics be the problem? an why is the battery lite on now i read about a fuse link but cant find it there is a black narrow and about 6 inch long box from the battery to the starter relay on the fire wall is that it ?
SOURCE: Hooked up battery wrong
hey its the main fuse in the fuse box in the front of the car. its a little square box clear on the topside and i believe its yellow on the sides. its a big one, 100 amp I think. u can pick one up at any auto parts store. main fuse.
SOURCE: 1997 pontiac not turning over
to turn the theft lock off you must put key into ignition and turn to ACC, wait ten minutes (light will turn off) then turn the key to off position and pull out. Do this 3 times ( i know 30 minutes is a long time) and then after that the theft lock will turn off and your car SHOULD start.
SOURCE: I have a 1999 jeep cherokee 4x4 4.0L I6. I was
If you had a short that large before you started working on the batt cables, it would have burned long before it did. Check your work over and see where it's grounding. You can make a temporary link by using a new piece of wire the same as the gauge at both ends of the link and sectioning in a short piece of smaller ga. wire. Hopefully you didn't damage the alternator or other electronics. The original problem sounds like possibly the fuel pump anti drain-back valve is bad (integral with pump) Testing pressure will verify that.
You can disconnect alternator, but the fuse method you mentioned sounds more reasonable.
SOURCE: 1989 Honda Accord won't crank - starter good - what next?
check powers out of the ignition switch big in big out usually first place to start
SOURCE: Starter relay connections
if your starter engages but wont spin check to make sure the starter housing is making good contact on the bell housing or it wont ground out
It
can be faulty starter or there is loose connection from battery to starter. The
starter assembly gets power from battery. Check voltages at starter wires and
see if you are getting 12 volts or not. If not then its no power issue due to
low battery volt or no connection between battery to starter.
To
solve these problem, I suggest you to refer these direct help links:-----
Click
the link below: ------
How to test
starter solenoid?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html
How to test
cars starter?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html
How to
replace starter in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
These
will help.
Thanks.
