Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
SOURCE: hotpoint aquarius wmf 740 has error code f5 - what does it mean?
I think you mean F05, in which case it means that the pressure switch is jammed on full.
You need to remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well, and look inside the pump.
This should solve your problem.
SOURCE: im getting error code f-06 what does this mean?
sorry but f-06 is not coming up as an error code for this model, if you can post up the full model number or product number illlook into it again
