SOURCE: installation of cisco asa 5510 firewall
The problem is your version of java, you need to uninstall java 6 update 11 or 12 and install java 6 update 6. you can download this from the archive section at the java web site. I had the same problem but this solved it.
Good luck
pls send me a line if your problem is solve
[email protected]
SOURCE: Restart Cisco Asa 5510
Yes. The firewall will restart. Just be sure to save your running config to memory before turning off. For that you must issue the command: write memory.
Best Regards,
T
SOURCE: block websites on cisco asa 5510.
All websites or specific ones?
If you want to block all web traffic, a straightforward rule preventing HTTP traffic (TCP port 80) as well as HTTPS (port 443) will block any and all web access.
If you just want to block specific sites, I'd recommend an access control list (ACL) configured to deny traffic to those specific site's IP addresses.
SOURCE: i have cisco asa 5510 firewall and
Your best bet is to place the ASA into 'transparent' mode, and letting the traffic pass through it and be inspected on the way through.
To do this you need to first do the following command:
firewall transparent
Once in transparent mode, the firewall will no longer look like a hop in the packets journey, and you can set rules to allow/disallow traffic using access lists on the inside and outside interfaces, plus you can perform packet inspections using policy-map and inspects.
Hope that helps!
