Question about Nfive Number5 Software Card Five - Replacement USB Key (P/N USBKEY)
Unexpected file format
Generic error unable to load the card document
Unexpected file format error
that is nasty. have you tried with system restore ? maybe it helps ...
Apr 29, 2013 | Novatel Art Explosion Publisher Pro for PC
Can't save world document in 2010 office
Losing work is great for terrible moods.
There is nothing like spending an hour hammering away at your keyboard making edits to an important document, only to find that you're unable to save it when you're done.
If you're experiencing this issue and Microsoft Word is throwing errors instead of saving your hard work, there is still hope for you.
There's a good chance the file you're working on is read-only.
Saving a new copy will often fix this issue.
If you can't do that, copying the body of a document to another application should do the trick.
Select the "File" tab on the Microsoft Word toolbar. Click "Save As."
Browse to the location you wish to store the file in. Select a format from the "Save as type" drop-down list.
Microsoft Word 2010 will default to the .docx format.
Use "Word 97-2003 Document" to save the file as a .doc file.
Type a name for the file and click "Save."
A new copy of the document will be saved to the location you specified.
Your edits will be included in this new document.
This procedure will get you around read-only permissions.
Use Another Program
Select your Microsoft Work window and press "Ctrl" and "A" simultaneously.
This will highlight the entire document.
Press "Ctrl" and "C" simultaneously to copy the whole document to the Windows clipboard.
Launch an alternate text-editing application.
WordPad and Notepad are included with Windows so they make a logical choice.
Applications like Microsoft Works Word Processor or AbiWord should work as well.
Press "Ctrl and "V" simultaneously to paste your document into the second application.
Click "File" and select "Save As." Select a location, a format and a name for the file and click "Save."
Hope this helps
Oct 25, 2012 | SanDisk 2GB microSD Memory Card
I got a Kingston 4GB Data traveller pen drive which when plugged into the usb slot gets detected and also opens fine but when i try to send in files to it it says : "Windows was unable to save all the data...
hi,
its not a issue , down load HP low device formatting freeware , then format your usb using that software , then reboot you computer inject the usb, again format your usb in windows , use FAT32, not ntfc to format, it will for mat then try to save it it will , its nothin your usb is affected by autoexe virus it will be find if you follow what i said,
thank you,
domnickr...
Sep 14, 2010 | Kingston 4GB Secure Digital High Capacity...
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Cannot open file - "Unexpected File Format"
Does the program allow for "auto back Up?" if so I would look in the folder of the original file and look for one closely named but probably with a different extension, if it exists rename it a different name than the original and with the proper extension. then try it. If not you have probably lost your work due to improper closing of the file when your computer crashed. You could try the manufactures web site and look for a corrupt file recovery tool of some sort. Sorry I could not help more.
Apr 03, 2009 | Final Draft 7
Memory card write protect?
point out a file to unprotect. and right click your mouse and go to properties and select it as archive (or) un hidden
if same problem
some virus cases try to scan or delete virus using some antivirus software. and try it
(or)
finaly go to formate your memory card.(in case your files or deleted) only use this as alost chance
by
yv sharma
Nov 07, 2008 | Samsung SGH-E900 Cellular Phone
Micro sd card cannot be formatted?my phone is T11 celphone?
how can i use the usb cable of this stupid T11 phone?!!!
May 27, 2008 | Cell Phones
Audiophase KZ111 manual
try to find the file extension . something like .doc .xls .txt and find the application for the extension using google
Dec 25, 2007 | Audio Players & Recorders
Nfive Number5 Software Card Five - Replacement USB Key (P/N USBKEY) Logo
257 people viewed this question
Top Nfive Computers & Internet Experts
Alun Cox
Are you a Nfive Computer and Internet Expert? Answer questions, earn points and help others
