Question about Nostalgia Electrics Helman Group CCP-510 Circus Cart Popcorn Maker
12v supply for 2005 ford mondeo
Behind glove box in 2005 mondeo is main fuseboard and a blue and a brown connector box. which terminal on either will give me a supply and earth which is only on with ignition. I am using the top terminal of blue connector for my 12v but when windscreen washers used this interferes with the supply to my aux instrument.
Where is the computer box located in a 97 avallon
Instructions
    • 1
      Remove the battery cover to access the battery terminals. Disconnect the negative (-) battery cable with the pliers.
    • 2
      Open the glove box door and squeeze the outer part to remove the door. Locate the two screws behind the door to remove the glove box.
    • Sponsored Links
    • 3
      Access the ECU behind the glove box. Remove the electrical connectors by hand; remove the bolts mounting the ECU to the inner dash.
    • 4
      Install the new ECU in the same position. Replace the bolts and reconnect the electrical connectors.
    • 5
      Replace the glove box and the glove box door. Reconnect your battery.
Sponsored Links
Read more: How to Replace a Toyota Avalon ECU ' eHow.com http://www.ehow.com/how_6170111_replace-toyota-avalon-ecu.html#ixzz289jiGlka
Oct 02, 2012 | Toyota Avalon Cars & Trucks
Tip
Fuse list ford contour
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit
Engine bay fuse box
1 80 Black Power supply to main fuse box
2 60 Yellow Radiator fan
3 60 Yellow ABS
4 20 Yellow Daytime running lights
5 30 Light green Fog lamp
6 30 Light green Not used
7 30 Light green ABS
8 30 Light green Air pump
9 20 Light bue PCM module
10 20 Light bue Ignition switch
11 3 Violet PCM memory
12 15 Light bue Horn & hazard flasher
13 15 Light bue Oxygen sensor
14 15 Light bue Fuel pump
15 10 Red Right-hand low beam
Passenger compartment fuse box
16 10 Red Left-hand low beam
17 10 Red Right-hand high beam
18 10 Red Left-hand high beam
19 7.5 Brown Heated door mirrors
20 10 Black Windshield wipers
21 30 Light green Electric windows
22 7.5 Brown ABS
23 15 Light bue Reverse lights
24 15 Light bue Brake lights
25 20 Yellow Door locks
26 20 Yellow Main light
27 15 Light bue Cigarette lighter
28 30 Light green Power seats
29 30 Light green Heated rear window
30 7.5 Brown Engine management
31 7.5 Brown Instrument pannel lights
32 7.5 Brown Radio
33 7.5 Brown Front and rear sidelights (left)
34 7.5 Brown Interior lighting & clock
35 7.5 Brown Front and rear sidelights (right)
36 30 Light green Air bag
37 30 Light green Heated blower
38 Unused
Relays Color Circuit Location
Engine bay fuse box
R1 Green Daytime running lights (Canada)
R2 Black Radiator fan (high speed)
R3 Blue AC cut-out
R4 Brown AC clutch
R5 Dark green Radiator fan (low speed)
R6 Yellow Starter
R7 Brown Horns
R8 Brown Fuel pump
R9 White Low beam headlights
R10 White High beam headlights
R11 Brown PCM power supply
R12 White Interior and courtesy lights
R13 Yellow Heated rear window
R14 Yellow Heated blower
R15 Green Windshield wiper motor
R16 Black Ignition
R17 Unused
R18 Black One touch window switch Driver's door
R19 Blue Cruise control cut-off Central fuse box bracket
R20 Unused
R21 Unused
R22 White Fog lights Interface module bracket
R23 Black Turn signals Steering column
R24 White Left-hand flasher Door lock module bracket
R25 White Right-hand flasher Door lock module bracket
R26 Unused
Bulbs / Lights Wattage Type
Low beam headlamp 55 9006 Halogen
High beam headlamp 55 9005 Halogen
Parking / Side light 5 2357A Wedge
Front turn signal 21 2357A Bayonet
Rear turn signal 21 1157 Bayonet
Tail light 21 1157 Bayonet
Stop light 21 1157 Bayonet
High mount stop light 5 2723 Bayonet
Fog/Driving light 55 893 Halogen
License plate 5 6418 Festoon
Reverse light 21 1156 Bayonet
Front sidemarker 5 2357A Wedge
Glove box
Map light 5 64111 Wedge
Dome light 10 6411 Feston
Step/Courtesy light
Trunk/Cargo area
Engine compartment 10 89 Wedge
Instrument-general
Automatic trans indicator
on Apr 15, 2015 | Ford Contour Cars & Trucks
DIAGNOSTIC TROUBLE CODE P0135.
Here are the reasons for that code:
HO2S no. 1 heater circut is open or shorted
HO2S no. 1 is defective
Defective ECM
Using a scan tool, read freeze frame data. Freeze fram data records engine conditions when a malfunction is detected.
Access ECM behind glove box. Turn ignition on. Using DVOM, backprobe ECM harness connector. If DTC P0135 is set, measure voltage between ground and terminal No. 3 (Blue/Black wire) at ECM harness connector E10. If DTC P0155 is set, measure voltage between ground and terminal No. 4 (Yellow/Red wire) at ECM harness E10. Voltage should be 9-14 volts at each terminal. If voltage is as specified, replace ECM.
If not, Disconnect suspect HO2S No. 1 harness connector. Measure resistance between terminals B+ (Black/Yellow wire) and HT (Blue/Black wire on bank No. 1 ; Yellow/Red wire on bank No. 2) at HO2S connector (component side). Resistance should be 11-16 ohms at 68 degrees F and 23-32 ohms at 1472 degrees F. If resistance are not specified, replace appropriate HO2S. If resistance are specified, Repair wiring between ECM and appropriate HO2S, or between appropriate HO2S and EFI main relay (Black/Yellow wire at HO2S and Red wire at EFI main relay)
Mar 16, 2011 | 2002 Dodge Grand Caravan
What is check engine code p0135
Reasons are:
Defective ECM
Mar 16, 2011 | 2003 Toyota Tacoma
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
I need to disable my alarm on a 1997 bmw 528i.
Now im not sure since the manual says your model has the same alarm system as the 328i and on the 328i you can remove the module to disable by doing the following. you can unplug the control module. It is located under the glove box. Climb under the dash on the passenger side and remove a few screws on the trim panel under the glove box. Theres a black control module with a green connector. There should be a lock tab on the connector. press the lock tab and pull out the connector. The alarm should now be disabled. But if it has the special transponder key this may not work.
But if the only reason you want to disable it is because of the motion sensor setting of the alarm for no reason there is a solution for this. To disable the motion sensor, hit the lock button to arm, then hit lock button again within four seconds to disable motion sensor. Red light on rearview mirror should flash four times, then pause, then start flashing on regular intervals. this is most likely the reason if your having the issue where the alarm goes off every 20 minutes.
If you want to completely remove it below is a wiring diagram taken from the manual for you alarm system.
this is from the manual its the alarm wiring diagram.
Battery Constant 12v Positive Wire ( ): Red/White or RedBattery Constant 12v Positive Wire Location: Ignition Switch Harness
Starter Positive Wire ( ): Black/Yellow or Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire ( ): Green
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire ( ): Purple/White or Purple
Second Ignition Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire ( ): Gray/Purple and Gray/Yellow. Use Both Wires. This vehicle has a dual parking light system that will require 2 extra relays.
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire ( ): White/Red
Power Door Lock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Power Door Unlock Positive Wire ( ): Blue/Red
Power Door Unlock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Door Trigger Negative Wire (-): Brown/Gray
Door Trigger Negative Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Domelight Supervision Wire: Turns On With Unlock
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Brown/Red or Brown/Yellow
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Instrument Cluster
Brake Light Positive Wire ( ): Blue/Red or Green/Red
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Disarms With Factory Remote Only. Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: Transponder Anti-Theft System, Requires Bypass And Extra Ignition Key. The 1997 model year vehicle may require a bypass module and an extra ignition key, if vehicle is equipped with a special key from BMW.
Factory Anti-Theft System Location: Transponder At Ignition Switch Tumbler
if you require further assistance please let me know and i will help assist you from there. Thanks, Midwest-Tek
Aug 27, 2010 | 1997 BMW 328
I changed my blower fan control (in dash unit)new resistor and relay and still no go any tips
remove the heater control head
there is a square connector with 8 terminals but only uses 6 wires
the connector is black it will have YELLOW,LIGHT BLUE,ORANGE,BROWN wires and i can't remember the other colors
the BROWN wire is the main feed for the control head check for 12V
if you do not have 12V then there is a open between the connector and the fuse pannel
if you have 12V then make sure the plug is not melted and the terminal is good
hope this helps
Feb 19, 2010 | 1996 GMC Sierra
P0450 CODE ON 1997 T100 V6 PICKUP. WHAT IS it and how can I fix it?
Good day
P0450 is Evaporate emission system pressure sensor/switch
the cause could be
1. short or open in the vapor pressure sensor circuit
2.vapour pressure sensor
3. ECM
You can test with the following
you can access the ECM behind the glove box. turn ignition on,backprobe the ECM connector, on A/T models, measure voltage between terminals #1 (green/black wire) and #22 (brown/black wire) at the ECM E6 connector. on M/T models measure the voltage between terminals #1 (green/black wire) and #9 (brown/black wire) at ECM E6. if voltage is 4.5 - 5.5 volts, go to the next step. If the voltage is not 4.5 - 5.5 volts, replace ECM and retest.
2. back-probe ECM connector on A/T models measure voltage between terminals #15 (red/blue wire) and #22 (brown/black wire) at ECM E6. on M/T models measure voltage between terminals #4 (red/blue wire) at ECM E5 and connector #9 (brown/black wire) at ECM E6 connector. on all models disconnect the vacuum hose from the vapor pressure sensor. sensor is located near the brake master cylinder. connect a vacuum pump to sensor. if voltage is 2.9-3.7 volts without vacuum applied and 1.3-2.1 volts with .59 in.Hg (2kpa) vacuum applied. replace ECM and retest if voltage is not as specified go to next step.
3. check for open r short circuit in the wiring harness between vapor pressure sensor and ECM. repair wiring as necessary. if wiring harness is okay replace the vapor pressure sensor.
Hope this helps
Cheers
Jul 13, 2009 | 1997 Toyota T100
The stereo wire colors for the 2001 chevy s 10
Radio 12v  orange  +  radio harness Radio Ground  black  -  radio harness Radio Ignition  dk. green  +  radio harness Radio Illumination  brown  +  radio harness Factory Amp Turn-on  orange  +  radio harness Notes: The amplifier is behind the glove box. Power Antenna  N/A     LF Speaker +/-  tan - gray  +,-  radio harness RF Speaker +/-  lt. green - dk. green  +,-  radio harness LR Speaker +/-  brown - yellow  +,-  radio harness RR Speaker +/-  dk. blue - lt. blue  +,-  radio harness
May 02, 2009 | 2002 Chevrolet S-10
Nostalgia Electrics Helman Group CCP-510 Circus Cart Popcorn Maker Logo
97 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Sheldon Dedek
ray gallant
ray gallant
Gil Shultz
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
