Jacuzzi BK37959
SOURCE: Jacuzzi BK37959 can't install Floodsafe auto-shutoff toilet conn?
just remove the filter, it will work properly
SOURCE: my flapper leaks,only 1yr. old.jacuzzi model
Hi and welcome to fixya, try giveing some slack to the chain that conects to the handel, its likliy too tight and keeping it open.
SOURCE: We bought the Jacuzzi Perfecta toilet 1 year ago
The complication here is that Jacuzzi does not make toilets anymore than Sears makes refrigerators. In Sear's case their Kenmore refrigerators are from Whirlpool with the Kenmore name.
It is my understanding that Eljer was the manufacturer of the toilets with the Jacuzzi name typically sold at box stores. With that as a starting point, surf the web for any Eljer toilet tank replacement parts and see if you can find a similiar flusher
SOURCE: replacing flush valve jacuzzi toilet
I am having the same problem. Looks like we'll need to order directly from the manufacturer.
SOURCE: i need to replace the wax seal on my jacuzzi
I would just use the one from hardware store. nothing special about the wax from the manufacturer except the price...
be sure to do a thurough cleaning on the bottom of the toilet and make sure it is dry before you install new wax ring or it will leak.
you can actually use a hair dryer or set it in the sun to soften the wax ring, don't melt it, just soften it. makes a much easier time when setting the toilet down onto the wax.
